Cooking nando's chicken at home!?
Why? It's been cooked so the bacteria has been killed it's been frozen so nothing else will have grown and as long as you don't defrost it in a warm room for days it'll be fine to defrost and eat without reheating.
To be honest, I don't know. It's just doesn't seem right. I'm very much of the opinion that it'd be good to reheat (properly!) to kill off anything. I guess one argument is that as you cook it once then freeze it, it goes through the 'danger temperatures' for growing bacteria.. but then again it would from re-heating it again anyway. I'm probably just paranoid.
There's nothing to kill off. You've already cooked it. If your concerns were true, you couldn't eat cold chicken sammiches.
It's perfectly fine though it's generally a good idea to cool/freeze it as quickly as possible after cooking - both from a safety perspective as well as preserving the quality of the meat.
why the bacteria is killed when its cooked
I'd be more dubious of buying raw chicken
even the packaging can make you seriously ill
Yeah...but with raw chicken you don't eat the packaging and you cook it yourself in conditions you are fully in control of. You then also keep it frozen in conditions you are in control of, rather than being at the mercy of some customer that left it out of the freezer for half a day until a member of staff chucked it back in to be re-frozen.
but you do touch the packaging at a time when cleaning your hands is not really possible.
then you walk around the shop touching loads of other stuff spreading it around the store.
you might then have to lick your finger in order to open a shopping bag
Not true. I haven't got time to find links now but bacteria can form when the meat is in the right temperature range for it to grow. Probably somewhere around room temperature. That's why you try to cool stuff quickly, it passes through the danger temperatures quicker.
Well of course, but then I'm assuming you're taking care of your food properly, and not leaving it on the stove to crust up before putting it in the fridge.
Isn't the sauce recipe originally Portuguese rather than South African? I know that piri piri is a SA chilli/spice of course.
Peri peri (piri piri, or whatever) originates from Mozambique, in terms of both teh sauce and the language of the word. The plant is native to several African countries. The chicken restaurant itself that served the meal originated as a Portuguese takeaway in South Africa, which was then purchased by two guys (one Saffie, one Portuguese) and turned into Nandos.
Ok, complete cooking noob here. I want to start taking my own meals to work on weekends (chicken and rice). I've bought a load of chicken breasts and Im gonna cook them and freeze them and thaw em out day before work etc.
I've bought some nando's peri peri sauce 'hot' - do I apply this to the chicken BEFORE or AFTER cooking them? The bottle doesn't say.
Cheers!
they do two types, one is a marinade which goes on some time before cooking, and the other is a sauce to add after cooking,
next time get the nandos dry rub and add some of that before cooking/freezing the chicken for best results imo
sauce..
marinade..
dry rub, best one to use imo...
Oven cooking chicken breast, bleurgh..
When I can't be bothered waiting for Sous Vide, I always oven cook chicken breast. A few minutes skin-side down in a frying pan on high, then chuck it in the oven (pre-heated to about 160/170) and take it out in ten minutes or so once it hits 60C internal. Great every time.
Pan roasted chicken is indeed awesome. I do similar to uv though I use the oven in grill mode. Pre-heat the cast iron pan to screaming hot then place the breasts skin-up and put under the grill. 5-8 minutes and you're done.
