Thanks for your help. I'm just going to by the LG G3 instead of faffing about. i'll put the G2 on ebay/gumtree and let someone else try to fix it.
Have you ever used Fastboot before? You could probably fix the problem with that.
I got my G2 yesterday and it's now my favourite phone I've had yet.
I liked the G3 but it was a bit too big and the G2 is just the right size. Plus the screen is superb.
ROMing itGood to hear. Are you ROMing or sticking with stock?
ROMing itIt came with 4.4.2 stock on and I actually really liked it. I was tempted to keep it.....for a few hours at least.
Which ROM are you going to use? Tried flashing http://forum.xda-developers.com/lg-g2/development-d802/rom-xenonhd-d802-t3036576 recently, but failed because I was on lollipop firmware. Thinking of trying again though, or do you have any suggestion?
That worked it's now updating.
Cheers
Quick question if you don't mind MOOGLEYS. Is there an OTA to lollipop for the G2 D802? Or is it only updateable using that link from the previous page and that downloadable support tool thingy?
This is not for me but my bro has a G2 and still hasn't been updated...
Thanks.
I have no idea tbh. I did mine using the lg software as I kept reading it was released but I never got any update notifications for OTA ?
It does seem that the G2 & G3 will be getting Android M so maybe they are holding off OTA updates until thus is released.
