Hi guys, been you tubing is a 'blade glimpse' alright for a start (toy) found it for £150.
 I guess when I start tuning mine it should be a little more snappy and responsive?  Here is tonights quick test, you can see by swapping over to new frame, iv not eliminated the slight vibe stutter. No idea what it is, probably one of the motors, although it flys fine.
Whack some music on the video and you dont even notice it. The camera is not vibration proof yet. My 250 is also not tuned (PID) yet
seems to be pretty much what it was before, just need to ensure the VTX and camera stays reliable after some focus issues today
The quad is oscillating from too high PID settings, you might need to lower ever so slightly on the Roll and/or Pitch Axis. Alternatively, set some TPA - this lowers the PID's progressively as when you reach a certain throttle point. Useful if the quad is stable in a hover but shudders when you increase throttle!
If the quad is shaking from PID issues, no amount of anti-vibe material will get it out. I think you can tell the difference as vibes from a dodgy motor or prop will be more jello like.
Possibly as a result of the shakes![]()
Am I the only one who likes the shudder under WOT?
I must admit looking at your video that high PIDs are the first thing I thought about too. If it's during high throttle it's very likely.
The default settings are a starting point, motor, ESC, battery, weight are all factors which will influence it. Try creating different profiles with different PIDs (maybe one lower, one higher) which you can select with a Tx stick combo before you take off to test and try.
Is this even the case when I havnt even tuned the PID's? why would it be oscillating from too high PID's when everything is on default? iv got to tweak everything yet to dial it in? - I was actually hoping to dial it in so its more snappy, more locked in. So is this going to make the vibrations worse?
I managed to get a lot of the shakes out before using the foam, so it wasnt as bad as what it was now since iv had the new frame, I will use better foam still
I had shakes before and it didnt defocus anything, it was something on the camera that came loose
 Am I the only one who likes the shudder under WOT? It's like piloting a flying F1 car![]()
What's WOT?
Thats the point, its already default, so does this mean I cant tune up? im essentially going to have to "tune down" and lose performance?
all I want in is a locked in feel.
I will try different profiles, but dont understand why I have this as I thought the naze is supposed to be good out of the box without issues.
IE will tuning it down so I dont get throttle punch vibes will reduce performance?/ make it fly slower etc
