- 2 Jan 2012
- UK.
Nvidia already have their version of this out in the form of the Titan X and 980Ti. This is AMD's response.
I don't know why people are getting that excited about the specs. The 290x out specs the 980 GTX (see below) but we all know that does not translate so well into gaming performance.
Better floating-point performance
5,632 GFLOPS vs 4,616 GFLOPS More than 20% better floating-point performance
Significantly wider memory bus
512 bit vs 256 bit 2x wider memory bus
More shading units
2,816 vs 2,048 768 more shading units
More texture mapping units
176 vs 128 48 more texture mapping units
What you're comparing there is the 290X a near 2 year old design (GCN 1.0) VS Nvidia's latest architecture (Maxwell). It's not just the spec but the architecture used as well, comes with inherent improvements.
I.e new generation Maxwell cores VS GCN 1.0. Even then the near 2 year old 290X does pretty well against the GTX 980 especially at higher res.
So with Fiji and the new architecture not only do you have better spec in every metric (Except volume of memory) but also GCN 1.2 'newer architecture'.
Expect it to be quite a leap. Whether it can beat Titan X we will find out very soon. My money is on 10% - 15% faster than Titan X in all but Gameworks titles.
