What you're comparing there is the 290X a near 2 year old design (GCN 1.0) VS Nvidia's latest architecture (Maxwell). It's not just the spec but the architecture used as well, comes with inherent improvements.
I.e new generation Maxwell cores VS GCN 1.0. Even then the near 2 year old 290X does pretty well against the GTX 980 especially at higher res.
So with Fiji and the new architecture not only do you have better spec in every metric (Except volume of memory) but also GCN 1.2 'newer architecture'.
Expect it to be quite a leap. Whether it can beat Titan X we will find out very soon. My money is on 10% - 15% faster than Titan X in all but Gameworks titles.
That is one fast card LOL!
There seems to be a massive improvement in tesellation performance too!
But equally so is gm200, if these results are truthful
Yeah,but the GPU is smaller with Fiji it appears and if AMD have not massively reduced DP performance too,then its a big achievement over Hawaii,considering it is only 27% bigger.
Yeah but for instance in Witcher 3 it would just work without loads of crashing and the need for multiple new unstable drivers before you get a working one.
Not even close to the first time Nvidia's new game support is unstable as crap.
If AMD manage to get that much performance and the DP performance, well, they'll continue to be sold in every Apple product ahead of Nvidia cards for the foreseeable future.
Just noticed something else -
Why is the TX scoring less than a 980 Ti in some of the tests lol.
Very unlikely
Best test to see if any benchmarks are genuine is to compare them to the 295X2
Forget about memory speeds and just base it on the shaders and work out the % difference.
295X2 = 5632
Fiji = 4096 rumoured
which means the 295X2 should score about 37.5% more than Fiji
This all goes out the window if the Fiji architecture is very different to Hawaii
Using the table that has been posted on batman for example
Fury scored 65
295X2 should have scored 89.375
A couple of my old 290Xs scored 74 on the Batman AO bench maxed out including all the AA lol.
Very unlikely
295X2 = 5632
Fury scored 65
The 295X2 is GCN 1.1 with GDDR5.
This is GCN 1.3? with HBM.
Its far to easy to say Fiji will scale the same as Hawaii when you ignore the differences in technology.
