Right placing my order - Edge or not? I can't decide, money isn't really a factor but I'm worried the Edge features just won't ever be touched or used. It sounds like a cool gimmick that I'll never actually want to use.
Wahey, there's a fix for the RAM problem we have. Works like a charm on mine.
http://forum.xda-developers.com/tmobile-galaxy-s6/general/s6-ram-management-discussion-t3128229
How do you check what sensor you have? Not that it really matters as they surely have to be comparable.
Those pictures above are stunning for a phone camera!
Out of interest, and sorry I've not been keeping up with this thread, but is there a way to tell what sensor its got before you buy, and is it a noticeable difference between the Sony and Samsung sensors? Ta!
Look at the bottom of post 3813 from GS7.
Yes, I can get the screen up but can't interpret what I get.
Did you click isp ver check after opening the options page with the keypad?
I keep getting a "threat found" notification popping up. What can I do about this?
Edit. "Unauthorised actions" notification. Sorry
Tomasz Blaszynski (Samsung KNOX Support)
Jun 11, 00:51
Hello Tauren,
Thank you for contacting Samsung KNOX Support.
This issue has been fixed, and it will be available in the next MR (maintenance release) of firmware for your device which is planned for end of June.
If you require more help, do not hesitate to contact us directly.
Best regards,
Tomasz Blaszynski
Don't buy an edge for the features, I don't use them...they are rubbish.
Think of it as an Audi S-Line, you buy it because its pretty, not because its any faster.
Fresh reset, now I'm getting this, is it normal? I'm hoping its an indication the thing is now sleeping.
Whilst true, I still want the edge because i want something that looks pretty.![]()
Download CPU spy and it will show if the phone is deep sleeping.
Also did you root/custom recovery it?
