This is hard god damn work, I spend nearly 2 hours doing one stage in the Escort, about ready to put my foot through the computer, and then bang I put a time in 4 second faster than the others, over the moon, you forget all about the misery and continue to the next stage, rinse and repeat. This game is torturous.
Enjoying it more than Project cars though, that was annoying for no reason or fault of your own, you would use a run off strip on one lap fine, go near it on the next lap spin off and loose 10 places.
so brutal but when you get it right you feel like a champion
. must say im enjoying it. nice car to drive.i think its still on offer in steam. snap it up. bargin. £18.74
Finally found a car with the wheel that I feel feels the way it should. And it was a car I absolutely hated with the controller. Cosworth RS500. Everything feels right, although you have to rev the nuts off this car to get it to move. Second you red line it in most cars you shift up, in the cosworth you have to stay there for a bit longer otherwise you enter the next gear too slow, looks like it gets all it's power at its highest RPM.
It's the first car since getting the wheel that I feel like I can push it in. Every other one I have had to drive like a bitch to get it to stay on the track.
Maybe you are a bitch!
DG, i literally cannot catch you at all.. At any track![]()
.next is germany 1-2 weeks. then rallycross.then mp.finland.sweden. and so on.
buy it now before it goes up. £18 on steam.
