The Fury(X) Fiji Owners Thread
24 May 2011
Im sure ive seen it posted that even on 1080p Batman uses 6gb of a titanx card! :eek:
I'm pretty sure I implied this?
I think it's a fantastic looking card. Happy that they have decided to stop "we haz the longest card" nonsense. I bought an expensive motherboard so I can see it in all its black and red glory! Not to be covered up by a foot long grahpics card.
Has there been a confirmed price yet btw?
That wasn't by choice, but by necessity!
you know how memory works with games right?
Batman does use that much memory. It's poorly optimised!
Caporegime
12 Jul 2007
United Kingdom
How do you expect to have a tidy looking case with those tiny stretched cables going to 4 radiator positions? Enthoo Primo is a good case, but it doesn't work miracles.
Will see how it goes, I'm not worried about a few radiator hoses though. I just hope i can fit them all in okay and maintain good temps and good performance. I think I'll be okay, but you never know until you start fitting it all.
24 May 2011
Well if you can't I will be willing to buy a couple from you to alleviate your worries!
That's what she said.
Good morning :)
Good to see AMD have mature vendor reps! ;)
Will be interesting to see that, great case choice btw.:)
It was between the Enthoo Primo and Corsair 900D for me. I went for the 900D:)
7 Feb 2011
Holywood, County Down
Benches from the site getting a lot of traffic right now..
Caporegime
14 Dec 2005
armoy, n. ireland
It is an epic case, I can vouch for that :)
Heavy beast though. I reckon the hdd cages and the rear fan mounts could maybe take the 4 aio rads. If you have a large air cooler, this will rule out some of the top fan mounts. Bottom ones aren't much use unless you have the case raised up a bit. Few owners on here have them on castor bases. Improves intake and makes it easier to move the case.
18 Oct 2002
EGBB
35 kg - empty :eek:
19 Feb 2007
ArcCorp
