- 9 Jul 2013
It will only get better, stay tuned!
What do you know, tell us tell us now
Matt, if you didn't get any sort of contribution towards your Fury setup, then you should have done.
It's about as good as anything AMD's PR department have come up with and most probably convinced a few people to take the plunge on a Fury (or 2).
is there anyway to stop this coil whine without having to swap the card?
What does worry me about the Fury X though is the fan on the rad. I've got 1850rpm GTs and they are definitely not quiet at that speed. I seem to recall having to take them down to around 1000-1200rpm to be bearable.
Hopefully the fact that these are (I believe) the 3000+rpm variety undervolted (or something) to run at 1850rpm will somehow make them quieter. Can't really see it though (which is why I'm worried).
Feels odd talking about a reference AMD cooler and talking about it being quiet rather than just "not waking the neighbours" loud...
Cap the frame rate or try using individual 8 pin connector cables if you are using 2 way splitters.
Failing that keep buying PSU's till one gets you a better result, or keep buying Fury X cards till one gets you a better result.
lol.
This maybe explains why gentle typhoons were so hard to find. AMD bought all the stock.![]()
JayZTwoCents video was useless.
no i am not going to keep buying psu's or fury x's overclockers can sort it out, this should have been fixed as this is retail and it clearly hasnt
I was being sarcastic, but to denote the fact that coilwhine is not indicative of a fault with any one particular product
This guy could learn a thing or too about it as well.
well if it was suposably fixed for retail why does mine sound like a review sample then! wheres gibbo when we him
