The Fury(X) Fiji Owners Thread
Well the monitor is as new so hopefully Ocuk being as good as they are, I should have no issues :)
Just ordered the Acer freesync monitor :)
Go for the BenQ dude, it has an updated firmware to address the ghosting issue. Not sure the Acer panel has updated firmware yet.
the noise is coming from the card itself not the radiator part lol so its the pump then?
Seems like it, i don't see how they can refuse an rma as amd have commented on it saying it was something that only affected review samples and they worked with coolermaster to fix it.
yeh thanx man im talking to bailey again in the support section but hes not having any of it :(
Makes no sense, amd themselves have stated that it shouldn't be present in the retail cards as its something they worked with coolermaster to fix. If something needs fixed its obviously an issue that shouldn't be present in the first place.
Heres what amd sent legit reviews on the pump whine.
As far as the high-pitched whine, AMD received feedback that during open bench testing some cards emit a mild “whining” noise. This is normal for most high speed liquid cooling pumps; Usually the end user cannot hear the noise as the pumps are installed in the chassis, and the radiator fan is louder than the pump. Since the AMD Radeon™ R9 FuryX radiator fan is near silent, this pump noise is more noticeable.
The issue is limited to a very small batch of initial production samples and we have worked with the manufacturer to improve the acoustic profile of the pump. This problem has been resolved and a fix added to production parts and is not an issue.” – AMD PR
http://www.legitreviews.com/amd-radeon-r9-fury-x-video-card-review_167134/11
Bottom line its an issue that should NOT be in the retail boards, imo its ground for an rma.
http://wccftech.com/amd-radeon-fury-x-reportedly-suffering-buzzing-coil-whine/
They're also reporting on it.
Roll of honor please MSI received on 26th
Shame about the whine :(
You have it on your bed.. have you been doing 'things' with it? :eek:
Is that a pube on there ?
:D
Windows 10 still a no go atm?
Supposed to be a driver for Windows 10 through the Windows Update for Fury, or can use the modded .1040s.
