Likely the card then, unfortunately even with cards that aren't reported to have coil whine there's a small batch of all cards that do so.
, left if for a few minutes and still nothing. I had no choice but to power off with the case button. Started up and no display, got extremely nervous here. While still on I plugged my HDMI cable into the motherboard and the IGP display worked instantly and I could see both 980 Ti's in the device manager though unusable.
Tweaked the BIOS on both of my MSI GTX 980TI GAMING 6G, didn't like the fans turning off and having high idle temps of 38 to 40c. My room is very warm at the moment, just over 25c, case temp is 27c.
Even at 60% fan speed I cannot hear the fans on these cards over my case fans, so I saved the BIOS with nvflash, GPU-Z 0.84 kept freezing for some reason. Worked ok on my 980 G1's.
I changed the the minimum fan speed on both to 15% (660rpm), my cards now idle at 31c in a 27c case temp, much better.
Here is the original BIOS
Getting around 28c at idle on the msi GE. But then there's four fans intaking at the case front and hdd trays, then another two intakes at bottom.
When flashing 980ti's you have to disable them in device manager first
EK_Luc
About the 980Ti Classy...
I received a fair amount of emails since the reply from one of our rep being posted here.
For now, I don't have a firm answer to this question about the block for the 980Ti Classy.
There's currently discussions between EVGA and EK about it.
As soon as I personaly receive an answer, I will keep you updated here.
Sorry for the inconvenience.
What framerates are people getting in GTA 5 at Ultra with MSAA on etc?
I'm considering getting one of these, (maybe another in a few months) but I play at 5760x1080 and all the game benchmarks I find for GTA seem to vary at least 10fps between sites, with each using diff settings?
Thanks
I play at 3440x1440 and have everything maxed but no AA as I don't find it nessasary at the PPI I have! I get between 70-90 FPS depending on location, my average frame-rate from the built-in benchmark was 82FPS.
