The GTX 980 Ti owners thread.
What sort of temps are you seeing? Am really torn between this card and a Fury X. The more i read about the Ti the more it seems the better option. What are others opinions. One good thing is that the Ti can be had now. The MSI one interests me as it seems to be about the quietest from what i have seen.
With the fan set to a constant 80%, I was seeing 75c. It's hella quiet.
EDIT: Temps are 69c @ 85% with +120Mhz extra on the core clock.
Anyone had their card not showing any signal? Installed mine and got it plugged in through display port but not getting any monitor signal at all, does that mean the card is faulty? On an Asus x-99 board btw.
Nice. I really want an improvement over my Tri X 290 in terms of noise, running at 60% fan speed is quite audible especially since i play mostly at night when everything seems louder anyway.
well they are up and running
smashed my previous firestrike score from my 7970's. now to start overclocking
What sort of temps should i stay below? I just ran firestrike and was at 83c with 98% fan and was almost silent! :eek:
I want to get overclocking tomorrow if i've got the headroom. Not that i really need it but hey!
Also, someone explain how overclocking works with this boost clock thing? Nvidia is confusing, AMD is much easier.
AANNDDD.. How do i know what my card is boosting too?
Thanks :D
One last play with the clocks before I try a custom bios. I can run the card stable to 1450mhz with the stock voltage 1.187mv. Fairly surprised at that.
I've been a little supprised by my Zotac Amp similarly. It went to 1420/2025 on stock 1.187 voltage. Refuses to go beyond that though no matter how much mv I add and 100% fans.
Only an ASIC of like 68% though.
Wondering if wc will actually help or if this is its limit. Can't complain either way!
It being 36c here today probably didn't help too much.
Any tackled a custom bios for further overclocks?
Yup. Put one on my ocuk ref card (1.281v, 425w tdp limit) - does 1595core, 8400mem.
No idea if it gave me extra any extra OC as the first thing I did when I got the card was fit a water block and flash it.
Same asic as mine. Have you tried leaving the memory at stock and just pushing the core?
If Maxwell is anything like Kepler then wc didn't do much for me, yes temps are low and it runs silent but the bios always held you back from pumping more volts through the chip. Fermi was the last gpu I saw benefit from wc on a stock bios.
I guess though the overclocks everyone seem to be getting on these 980Ti's are more than decent enough and not to be sniffed at. :)
