** THE PHANTEKS ATX CASE YOU HAVE ALL REALLY BEEN WAITING FOR - TIME TO EVOLV **
Is it the end of July yet... want this case so bad! :)
Nope it's the 1st :) O/C still show 7th, CaseKing are showing stock arriving on the 17th, other shops show 31st and Phanteks say.....
( We know there have been a lot of questions regarding the release date of the Enthoo EVOLV ATX. Release date will be around end of July, 2015. )
You can work it out from there :)
Changed ours, we have guaranteed stock landing on the 31st July or 3rd August, depending on how fast the container clears at port. Other shops will not have their stock before us :)
I'm quite amazed that you know when other shops will receive stock :confused:
Is your stock via CaseKing ?
No, Caseking will get their stock after us too, it looks like most shops haven't updated their ETA's due to the delay which has a knock on effect.
P.S. I speak to Phanteks most days, I would hope that I would have my finger on the pulse when it comes to stock ETA's on their flagship products :)
Mine ordered, but no rush for me. Beginning of August is fine. Maybe some more info by then about availability of skylake+z170
Mine is preordered as well, it's all the dates flying about that gets confusing:)
The only thing that can be Guaranteed is that they will be sent to customers when they arrive.
I also have many leatherbound books. That's what we are here for anyway. Big shame the stock didn't arrive when it should have done but the case is worth the wait!
My current feelings for this case, pretty much summed up in one image. :)
In all seriousness though I'm very excited for this case, from what I have read/seen should be worth the wait!
Anyone who's using wc setup, what rads you thinking of using?
NexXxoS XT45 360 Top / NexXxoS XT45 240 Front
Was going to use a 420 on the top, but it won't clear the Memory.
That's if I like the case, been a Lian Li fan for many years, tried a few others but ... umm always end up back with Lian.
An EK 360 PE up top and an EK 280 CE at the front.
The latter isn't out yet, but should be by mid to late July according to EK.
Hence I'm not too worried about this delay!
Just seen this review for the case with lots of useful info about rad sizes and clearances.
Also shows just how snug it might be in there with some actual gear in!
Deffo going to have to change from one fat rad + one thin rad to two thin rads.
Might even put the 280 up top and the 360 up front, simply because the EK PE range are only 38mm thick, but the to be released CE range for 140mm fans are 45mm thick. Might need every bit of space I can!
