ooh hello my lovely, nice to meet you...
Congrats! for that price I'd expect it to come in a bit of a nicer box. I bought a cheap old EVGA 750Ti a while back and the box was a lot better than that!
Not that it really matters, but it's a nice touch.
Going direct to the Nvidia site to download the hotfix driver 353.38 got my OC sorted
That's the external box, the internal one is much nicer
EDIT: There u go
EDIT: There u go
didn't realise there was a pass the parcel type situation.I love how the EVGA card is film sealed, so you know it is brand new. I have had far to many experiences of buying new PC parts and getting second hand.
That mobo only has 2 slot spacing doesn't it? So the cards would be pretty close.
Indeed, I've had quite a few cards from OcUK in fact that have be used, I know this because I sent them the card(s) back (780Tis)
hmm.
really starting to think my card was one someone tested and saw the crap asic rating now.
should be a fair lottery for all I couldn't give a toss if your an ocuk employee doesn't give you the right to cherry pick cards at a customers expense
I'm not disappointed with the card and I don't wish to return it either way.Arknor - I doubt very highly that OCUK employees would do that so don't make accusations like that unless you're sure. They are on a job and they also have managers/leaders that would put a stop to that pretty quickly. Eventually people would notice and OCUK would lose it's hard won reputation and start seeing a much higher return/RMA rate that would cost it a lot of business.
My card has a pretty low ASIC rate too but it still Overclocks pretty well...I know it can be frustrating when your card doesn't quite OC as much as you want, but that's the lottery..only way to avoid it is by buying a binned chip card...and that extra cost vs. benefit may not be worth it...
I'm sure your card still beats most 980 and Fury X cards...don't forget a few months ago you had to buy a Titan X to get this kind of performance, regardless of your ASIC quality
Edit - Also check what driver you're using...make sure it's 353.38 as that improved my stable OC performance a lot
ASIC makes absolutely no difference to Overclocking. My best Titan X has a low ASIC and my best 980 Ti the same. They do well on AIR as well as LN2. ASIC makes no difference!!!
