ADSL line stats check.. line keeps dropping
Don
21 Oct 2002
Parts Unknown
This is a long line, ~4-5 miles from the exchange, it used to be pretty stable. For the past few months, have been having multiple disconnects every day.
Does the same with BT HomeHub and DSL-N55U.
Modulation : G.Dmt
Annex Mode : Annex A/L
Line State : up
Lan Tx : 1222222
Lan Rx : 1064101
ADSL Tx : 26982
ADSL Rx : 263409
CRC Down : 58
CRC Up : 6738
FEC Down : 131
FEC Up : 46024
HEC Down : 47073
HEC Up : 98
SNR Up : 7.0
SNR Down : 9.0
Line Attenuation Up : 31.5
Line Attenuation Down : 63.5
Data Rate Up : 416
Data Rate Down : 1760
I think there may be a line problem as it's dropping far more often than you'd put up with.
Thanks
Quite a few HEC errors on the downstream. I'm not sure if that's just a feature of a longer line though. What's the uptime?
SNR looks fine to me .
Mine as of just now :(
Modulation : G.Dmt
Line State : up
Lan Tx : 451644
Lan Rx : 289193
ADSL Tx : 255381
ADSL Rx : 32795931
CRC Down : 2
CRC Up : 80
FEC Down : 1193
FEC Up : 53053
HEC Down : 432
HEC Up : 22
SNR Up : 11.0
SNR Down : 11.0
Data Rate Up : 608
Data Rate Down : 2560
Can you hear any noise on the phone line ?
You need to start running a monitoring program to record the line drops
There is no clue in the stats
Used to be maybe one drop a week or so, now it's multiple drops per day.
Hi Mine has been the same I didn't know if it was my router on the way out to be honest, I contacted my ISP and they have run a number of tests and cant find anything wrong with the line.
I have an Netgear DG834N I could try on the line, I just cant seem to port forward well on it for my CCTV system.
Any recommendations? I can use either a dsl-n55u or BT homehub3
Try runnning a quiet line test and listen for any noise (particularly crackling).
Dial 17070 (preferably from a corded phone) and then press Option 2. If there is noise, you have a phone line fault.
My stats are apparently very good for my distance from the exchange.
