As Gibbo said: the card is pretty much silent. I was afraid after reading Guru3D's review, as they state it's rather loud, but that's not the case.Razor how are you finding the extreme? Can't wait to use a card that can legitimately push max settings at 1440p above 60fps. The 980 couldn't quite cut it.
Temps never went above 70 degrees (25 in the room) and fan speed between 30-45% - the case airflow probably helps.
Without touching the volts, it goes to 1505/8000. For more I would've to add some mV but I won't even bother.
It's just another goofy looking card which can share the top spot with 6G and G1.
) and the clockspeed is bouncing around between 1400-1500 under Heaven due to power limit being hit. I'm a bit weary of going any higher than 300W on power limit even though the EK waterblock should cool the VRM's amazingly well?
and it's keeping at 1493mhz in Heaven now, I will go for the big 1500mhz if nothing melts. What is the norm for memory overclocking? I currently have 3800mhz stable not tried higher though.
currently drinking my sorrows away in a Munich beer house after spending £610 haha
