Can you not do the Evga step up thing too?
Nope, only from 90days of purchase
I opted for the 980ti because it's pretty much even performance with the 980 SLI which I already have.
Single card v SLI for same performance = no brainer.
Hmm I think I'll need to research this some more.
980 SLI is the same performance as a 980Ti ?
LOL
Jubilee clips and barbs are far cheaper and just as reliable as a compression fitting although not as pretty to look at. Not sure I would have the balls to do undersized tubing and no clip like you have done even though I know it would probably be ok.
Trust me, once it's on and it's fairly easy to push with the tubing heated up it's HARD to get off, most people on this forum would struggle physically to pull it off. 1/2" tubing on 1/2" barbs definitely needs holding though.
Trust me, once it's on and it's fairly easy to push on with the tubing heated up it's HARD to get off, most people on this forum would struggle physically to pull it off. 1/2" tubing on 1/2" barbs definitely needs holding though. 7/16" tubing on 1/2" barbs also looks a lot cleaner than jubilee clips and suchlike. The physical effort it takes to pull the tubing off is probably the one major downside.
LOL
Firestrike is not really reflective of actual gaming performance. An aftermarket 980ti with a bit of an OC comes quite close indeed to SLI 980s in some games.
I didn't say it was, it was just an example.. However in 90% of the benchmarks the 980 SLI dominates the 980 ti. Remember my 980 is highly overclocked too!
I suppose I could look for a second hand 980, rather than new![]()
On Tuesday I'll have both SLI 980s and a 980ti so I could do some benchmarks for you if you like.
And if you're looking for a 2nd hand 980, check my sig.![]()
When I try to view the link in your siggy it says I dont have access. How do I get access?
BTW I have just ordered the KFA Hall Of Fame 980TI, no idea when OC will get stock though![]()
You can't, you don't meet the criteria to access that area of the forum.![]()
What is the criteria to get into this mysterious area of the forum?![]()
1,000 posts.
