- 24 Aug 2006
- Gibraltar
I just use £1.20 1/2" barbs with 7/16" ID tubing, if you dip the end of the tubing in some boiled water and then push it on it'll never fall off, in fact it takes a lot of effort just to pull it off yourself. If you go with fancy compression fittings and stuff it can soon mount up.
I did that in my 1st build. Lost x48 mobo,4gig ram and a 4890 gc
. On the Brightside it got replaced by x58 upgrade and 5870
