Permabanned
- 4 Sep 2011
- Durham
edit
Ive heard they pretty good but MSI (for me at least) have been kicking out this fantastic cooling system for ages and have more brand recognition. I know when I buy a gaming edition card it will be very quiet and very fast. The AMP card is a bit of an unknown quantity
Yeah but from everyone who has owned the Amp Extreme it is essentially silent at 40% fan speed at under 70c and boosts to over 1400mhz straight out of the box. That definitely has to put it at the top with if not above the MSI. I haven't heard of a single problem from anyone who owns one of these. No matter whether it's not as popular a brand as MSI it doesn't make the card any worse.
Cant really comment on the AMP having never owned one but even at 80% fan speed the MSI is barely audible. It may just be me but I feel more comfortable buying MSI![]()
finally managed to have a bit of a blast with the G1. After switching from 780ti SLI there is a huge difference in Shadow of Mordor at 1440p. Its wonderfully smooth. very happy with the swap![]()
I moved from sli 780 to a single ti, whilst i dont play those games mentioned. Its a nice improvement. Less power used, less heat and noise and more vram.Is it really that good? I have 780 SLI and really really tempted to go single card 980ti. Although most of the games I play perform great, its the occasional stuttering in Witch and GTA that are increasingly bugging me. Plus the odd tittle that doesn't support SLI eg Wolfenstien..
Why should it be 1.21?
My msi card does 1535 on 1.187
The card sticking to using a lower voltage is actually an indication you have a "good" chip as it means you have headroom to push higher
1.187 seems to be the standard voltage for a 980ti
Mid 60's/70's & 80's all downclock the GPU - to keep max clock you need to have it run at below 60c roughly to ensure it stays at max.
Cheers, I've set a custom profile topping out at 75% and it's doing the trick.
I didn't realise these cards ran so hot.
