are i see and congratulations on your baby boy and a agree with it being to hot but take us much tome off as you what mate![]()
Thanks Keechy, Im back on it today
Awesome update![]()
That's beautiful I love it so much what a great update
I hope mine looks even a third as awesome as your desk![]()
	Looks smart that. What paint did you use for the details? Brush or spray?
Looks absolutely amazing so far, really can't wait to see the finished project.
As for the hinges I would go with red but a darker, less glossy one than pictured
The hinges also? or just the speaker covers?
was also thinking of adding some red to the front fans if I add red to the speakers/hinges.
I meant to say the speaker surrounds however the hinges would look good in the same colour.
Get it depends on the ratio of red to black after it's all assembled
Great looking build so far, i would have opted to use a polyurethane expanding glue on the MDF all the heat weight
and expansion/contraction from the heat in the desk will eventually de bond the joints. Unless you pinned and screwed every joint? But i don't remember seeing that done in your posts.
Haven't checked this out for a while, come a long way and is looking great. Awesome job so far.
How long do you think is left?
Had never heard of that glue, but will try that out in the future should I use MDF again.
was warned about MDF once I started the build, so used MDF sealer on most the desk & all joints,
wood glue & screws or bolts was used on every joint apart from the parts that come away i.e the top, bottom left & right.
I hope nothing bad happens after all this work
but I always have the option of wrapping the whole thing, almost did that but changed my mind last minute.
painting was a lot more costly & hard, but glad atm I went with it.
