Vanilla - You dont have 8x AA enabled
That was it! AA enabled
Sorry i'm new to the whole benchmarking thing. Do you think it's my CPU that is holding me back now? It's pretty old and isn't Overclocked.
You want to have over 1500 core and +600 on your memory if you want to be near the top.
Heaven likes memory OC'd.
Where did you read it?
Anybody else having trouble flashing the bios?, getting this error - ERROR:BIOS Cert Verification Error & it's aborting the flash.
Using the 980Ti-SC-425 bios from overclock.net.
I've noticed that the MSI 6G idles at base clock (1139 / 3505) resulting in +60C idle temperatures. Shouldn't the card be downclocking when idle?
The zero fan thing is unattainable with this config.![]()
Check the power management in the control panel, set it to Adaptive.I've noticed that the MSI 6G idles at base clock (1139 / 3505) resulting in +60C idle temperatures. Shouldn't the card be downclocking when idle?
Yes it should drop the clocks when idle. Anything else utilisation your GPU at all at stock?
At desktop mine is at 135/405MHz, 0.848mv at 44C default fan profile at stock, that is fan speed on 0%.
Yes. It was at Max performance but I changed and rebooted before posting here.![]()
Is the Zotec extreme amp and MSI the ones to go for still? What's the Zotac RMA like?
