Stock volts, I just maxed the power limit to 109%, plus that memory oc wasn't stable as I was crashing in BF4 last night as you probably well know.
Good news is I found my stable overclock.
core clock: 1504 (+150)
Memory: 2003 (+500)
However I found last night when GPU boost 2.0 decides to play a merry dance that the games weren't really smooth.
I also fitted the H55 plus Kraken G10. Excuse the dust and messy cables, I will sort that out later as I was in a rush to get it done and had some unexpected problems along the way,
but it's all installed and running now.
Temps are fantastic and best of all that GPU Boost crap doesn't kick in and throttle my cards 12Mhz at 67 degrees celcius and cause sluggishness in games. Also I now have an almost silent system, it is amazing now quiet it is now.
I do intend to make a proper thread on the differences, TDP, and screenshots etc but it will take some time but for now here are the temp differences
Before Temps - Ambient 22.5c (Bear in mind that during these test runs the card throttled down to 1491Mhz after 67c and I had a high fan curve, whilst the MSI has an amazing cooler the fans weren't quiet although are very good):
- Idle - 28c
- Metro LL - 72c
- Valley - 69c
- Hitman Absolution - 59c
- BF4 30 minute multiplayer session, Conquest Large 64 Players - 70c
After Temps - Ambient 23.5 (No throttling due to temps)
- Idle - 22c
- Metro LL - 48c
- Valley - 44c
- Hitman Absolution - 35c
- BF4 30 minute multiplayer session, Conquest Large 64 Players - 46c
I will try and see what overclocks I can get later on on stock, but so far I am chuffed to bits.
