- 26 Dec 2003
- Cambs UK
I make up the amount that uses one or more whole bottles of flavour.
I use 100ml and 200ml bottles, but yes do it. So much easier
Where do you get them, eBay seemed to be the only placd I could find 50ml bottles
@VR
spoke to chris last night, I've sorted you out bud![]()
Haven't seen one of these on here yet, got it today...
It's been reported that dangerous chemicals are produced when you vape above certain temperatures.. also your wick will burn above certain temperatures.
it's meant to be safer and healthier to vape with temperature control, specially if your a noob and not experienced in stopping/preventing bad vapes like 'dry hits'. by reducing or cutting off the power if and when it gets too hot.
It only works with certain wire material such as pure nickel (ni200) and titanium (ti).
It will produce a cooler vape and often weaker vape, which some people like, and some people can't stand.
Righty, built again only using nickel this time, 5 wraps, 0.07ohm, tastes great,nice clouds and flavour and above all the istick 40w tc appears to actually work with it, must not like the occ nickel coils
Found out my sxk60 (v4s clone) won't fire below 0.1 either, brilliant
Was firing the titanium build at 100j, something silly like 115w, worked perfectly on the ipv4, really warm yet odd tasting vape.
Grade 1 from stealth vape, 26 awg: http://www.stealthvape.co.uk/wire/medial-grade1-titanium-wire. Quite easy to work with but gives an unusual vape in terms of flavor.
I can't decide if the istick TC40 works with Ti or not though, it vapes fine (better then the IPV4 tbh) but eleaf don't officially say its safe though a few sites selling it say its fine with Ti.
I figured out why I mistook the reel of Ti for Ni, the labels on them, I just grabbed the one with the bright blue label, I mean EVERYTHING with Ni200 in the vaping world is coded with blue isn't it? Well not these reels, its black and the Ti is blue
The first build came out at like 0.26ohm (6-7 wraps) and I thought "well, this is high for nickel isn't it?" haha
Time to go RTA shopping![]()
