The Shadow of Mordor Bench.
Man of Honour
21 May 2012
Dalek flagship
Settings.
Don't forget the HD Content DLC.
Simple Rules.
The settings for this bench are different to the old thread.
Any normal resolution can be used up to and including 4K.
Please post your GPU and CPU clocks.
Please post the resolution used.
Please post your results screenshot.
Please post what drivers you are using.
Old Shadow of Mordor Bench.
1 GPU 1080p
  1. Score Ave 214.62, Min 90.29, GPU TitanP @2088/2778, CPU 5820k @4.7, Greebo Link 372.90 Drivers
  2. Score Ave 155.84, Min 62.07, GPU 1080 @1840/2502, CPU 5930k @3.7, smogsy Link 372.70 Drivers
  3. Score Ave 136.76, Min 84.23, GPU 980 Ti @1560/2102, CPU 4930k @4.0, Kaapstad Link 359.06 Drivers
  4. Score Ave 128.94, Min 61.70, GPU TitanM @1260/2000, CPU 5960X @4.7, Silent_Scone Link 353.49 Drivers
  5. Score Ave 115.09, Min 70.21, GPU 980 Ti @1316/1750, CPU 4790k @4.7, whyscotty Link 353.30 Drivers
  6. Score Ave 96.72, Min 64.79, GPU Fury X @1125/500, CPU 5960X @4.9, AMDMatt Link 15.7 Drivers
  7. Score Ave 92.71, Min 64.30, GPU Fury P @1090/500, CPU 4790k @4.0, nashathedog Link 15.8 Drivers
  8. Score Ave 90.45, Min 44.97, GPU 290X @1225/1625, CPU 5960X @4.0, Kaapstad Link 15.7 Drivers
  9. Score Ave 49.54, Min 28.96, GPU 770 @1111/1753, CPU 3570k @3.5, trentlad Link 353.30 Drivers
2 GPU 1080p
  1. Score Ave 195.17, Min 86.31, GPU TitanM @1200/2000, CPU 5960X @4.7, Silent_Scone Link 353.49 Drivers
  2. Score Ave 190.37, Min 60.06, GPU Fury X @1125/500, CPU 5960X @4.9, AMDMatt Link 15.7 Drivers
3 GPU 1080p
4 GPU 1080p
1 GPU 1440p
  1. Score Ave 115.30, Min 61.07, GPU 1080 @1840/2502, CPU 5930k @3.7, smogsy Link 372.70 Drivers
  2. Score Ave 94.26, Min 60.20, GPU 980 Ti @1556/1940, CPU 4670k @4.2, Doobedoo Link 372.90 Drivers
  3. Score Ave 92.07, Min 61.01, GPU 980 Ti @1565/1930, CPU 4770k @4.6, zia Link 353.62 Drivers
  4. Score Ave 91.21, Min 45.60, GPU TitanM @1500/2000, CPU 5960X @4.4, Silent_Scone Link 353.62 Drivers
  5. Score Ave 90.38, Min 57.30, GPU TitanM @1477/2000, CPU 4770k @4.3, BG1980 Link 353.38 Drivers
  6. Score Ave 89.31, Min 55.74, GPU TitanM @1441/2000, CPU 3930k @4.625, Gregster Link 353.49 Drivers
  7. Score Ave 89.20, Min 59.32, GPU 980 Ti @1478/1850, CPU 4770k @4.7, pgi947 Link 353.51 Drivers
  8. Score Ave 88.84, Min 58.90, GPU 980 Ti @1520/2000, CPU 4770k @4.5, Robzere31 Link 353.62 Drivers
  9. Score Ave 88.58, Min 59.46, GPU TitanM @1441/2002, CPU 5960X @4.0, Kaapstad Link 353.30 Drivers
  10. Score Ave 87.75, Min 56.61, GPU TitanM @1445/2000, CPU 4770k @4.3, BG1980 Link 353.38 Drivers
  11. Score Ave 78.72, Min 53.36, GPU 980 Ti @1316/1750, CPU 4790k @4.7, whyscotty Link 353.30 Drivers
  12. Score Ave 71.74, Min 42.87, GPU 980 Ti @1265/1752, CPU i5 750 @2.8, monkentage Link 353.62 Drivers
  13. Score Ave 70.30, Min 35.61, GPU Fury X @1125/500, CPU 5960X @4.9, AMDMatt Link 15.7 Drivers
  14. Score Ave 63.99, Min 32.74, GPU 290X @1225/1625, CPU 5960X @4.0, Kaapstad Link 15.7 Drivers
2 GPU 1440p
  1. Score Ave 160.81, Min 39.39, GPU Fury X @1125/500, CPU 5960X @4.9, AMDMatt Link 15.7 Drivers
  2. Score Ave 147.31, Min 80.39, GPU TitanM @1420/2000, CPU 5960X @4.4, Silent_Scone Link 353.62 Drivers
3 GPU 1440p
  1. Score Ave 123.61, Min 62.49, GPU 970 @1342/1750, CPU 5820k @4.4, stooeh Link 353.30 Drivers
4 GPU 1440p
1 GPU 3440x1440
  1. Score Ave 90.19, Min 70.03, GPU Vega64 @1752/1100, CPU RZ1800X @4.1, AMDMatt Link 17.10.1 Drivers
  2. Score Ave 87.10, Min 52.13, GPU 1080 @2050/2700, CPU 5930k @4.4, String Link 378.49 Drivers
2 GPU 3440x1440
3 GPU 3440x1440
4 GPU 3440x1440
1 GPU 2160p
  1. Score Ave 79.41, Min 53.26, GPU TitanP @2088/2778, CPU 5820k @4.7, Greebo Link 372.90 Drivers
  2. Score Ave 63.19, Min 45.60, GPU 1080 @1840/2502, CPU 5930k @3.7, smogsy Link 372.70 Drivers
  3. Score Ave 44.57, Min 35.55, GPU TitanM @1260/2000, CPU 5960X @4.7, Silent_Scone Link 353.49 Drivers
  4. Score Ave 44.57, Min 35.37, GPU 980 Ti @1455/2052, CPU 4790k @4.7, whyscotty Link 353.30 Drivers
  5. Score Ave 44.33, Min 33.99, GPU TitanM @1475/2000, CPU 3930k @4.4, straxusii Link 353.62 Drivers
  6. Score Ave 43.72, Min 34.81, GPU TitanM @1441/2002, CPU 5960X @4.0, Kaapstad Link 353.30 Drivers
  7. Score Ave 41.60, Min 32.04, GPU TitanM @1409/2001, CPU 3930k @4.4, Gregster Link 353.38 Drivers
  8. Score Ave 39.05, Min 14.47, GPU Fury X @1125/500, CPU 5960X @4.9, AMDMatt Link 15.7 Drivers
2 GPU 2160p
  1. Score Ave 99.04, Min 18.51, GPU Fury X @1125/500, CPU 5960X @4.9, AMDMatt Link 15.7 Drivers
  2. Score Ave 85.46, Min 51.74, GPU TitanM @1455/2002, CPU 5960X @4.5, Kaapstad Link 353.30 Drivers
3 GPU 2160p
  1. Score Ave 143.05, Min 23.91, GPU Fury X @1050/500, CPU 5960X @4.9, AMDMatt Link 15.7 Drivers
  2. Score Ave 123.52, Min 66.54, GPU TitanM @1442/2002, CPU 5960X @4.5, Kaapstad Link 353.30 Drivers
4 GPU 2160p
  1. Score Ave 182.20, Min 5.76, GPU Fury X @1115/500, CPU 5960X @4.9, AMDMatt Link 15.7.1 Drivers
  2. Score Ave 150.84, Min 65.08, GPU TitanM @1442/2002, CPU 5960X @4.5, Kaapstad Link 355.60 Drivers
  3. Score Ave 107.13, Min 12.52, GPU 290X @1200/1500, CPU 5960X @4.0, Kaapstad Link 15.7 Drivers
5960X @4.9Ghz
Fury X
2160P
15.7
1xFury X @1125/500
2xFury X @1125/500
3xFury X @1125/500
4xFury X @1050/500
Multi Gpu runs are using AFR Friendly as it gives a boost to FPS over the default AMD SOM profile.
5960X @4.9Ghz
Fury X
2160P
15.7
1xFury X @1125/500
2xFury X @1125/500
3xFury X @1125/500
4xFury X @1050/500
A gain of 100 fps when going to 2 cards from 39 fps to 139 fps is a bit off really. Something not right there
AFR friendly improves the FPS dramatically and offers near perfect Crossfire scaling until four cards, whereas the default SOM profile offers less gains but smoother performance. It does not work in single gpu mode though. Kaap will be able to test and confirm using his Fury X's.
So you are saying that 1 card gave you 39 fps and using AFR friendly added 100 fps to bring it to 139 fps using 2 cards? That comes across as fishy to me.
Yup, the info is there so people can test for themselves. No negative side effects to using AFR Friendly either other than a bit more stuttering during the bench sequence and some menu flickering.
Interesting. I think I will start using LOD and things for bench threads then if your score is allowed, as you are modifying settings.
I've only changed the CrossFire profile from the default profile to AFR Friendly as it gives perfect CrossFire scaling. The results and method are there if Kaap wants to check. No image quality tweaks were made aside from frame pacing off and standard texture quality.
But you have gone from 39 fps to 139 fps. Sorry but that isn't perfect scaling, that is questionable scaling to me, as that is effectively running the same as 3.5 Fury Xs but only using 2 cards. Something definitely up with that.
Anyways, not my shout and Kaap can decide what to do but something is wrong there as perfect scaling would be 78 fps.
