- 11 Aug 2010
So, Triton turned up.
I stuck the 0.4 ohm coil in there, filled it up and let her rip. Currently vaping at 50W with pretty amazing vapour production for a pre-built coil tank. Flavour is OK too.
Observations:
RBA section is too small to get a ni200 build inside. Interesting design though and I'm keen to put a build in there. At work at the moment and don't have my coiling gear with me so this will have to wait until I get home.
Tank is too small. At 50W I burned through a tank of juice in 5 minutes. Definitely need to take spare juice with you if this is your all day tank.
Ratings on the coils are odd. The 0.4 ohm coil is rated at 25 - 30W but at these settings they produce hardly any vapour and no flavour. It starts to get good at 40W and at the moment 50W seems to be my sweet spot. I'll crank it up further once the coil is bedded in.
God knows how you are supposed to clean this tank. There is absolutely no way to get inside it...
Airflow control on the driptip base is interesting but I doubt I'll use it.
Triton works so much better with the Atlantis 2 coils, especially the 0.3ohm version. I think it was pbusardo who said they are using Stainless Steel rather than Kanthal for their Triton tanks, I suppose that could be the reason for difference in taste/performance.
