- 19 Jul 2013
- derby
was it relatively easy to take apart? mines auto firing want to try and get it working again.
EDIT: Nvm it was easy as pie
You guys with the auto-firing iStick 50s... when did you buy yours?
RBA section is too small to get a ni200 build inside. Interesting design though and I'm keen to put a build in there. At work at the moment and don't have my coiling gear with me so this will have to wait until I get home.
Made up a slurricane clone tonight, and wow, it's incredible!
http://e-liquid-recipes.com/recipe/46694/Slurricane+by+Ruthless
You get the strawberry and peach with a nice bit of twang from the tangerine, best way I can describe it![]()
Nice one Tommy, going to give that a bash, love the fruityness of sluricane.
Got my sigelli 30w coming tiday, 2 new 18650 Sony Blues, 100ml vpg mix and some concentrate, actually have vape mail for a change!
That also sounds good Tommy, never tried Sluricane, but it sounds great! The Mrs would love it, she loves a good fruity juice.
OK, Triton RBA....
I put a build in there last night and it's OK. Not a patch on the pre-built coils though. It vaped well at 30W but just can't wick fast enough for anything higher. That was 5 wraps of 24awg Kanthal, 3mm @ 0.5 ohms.
I think I can get a ni200 build in there if I use 30awg at 3mm. 5 wraps should be 0.1ohms. I will have a go with that tonight.
The RBA looks like it would be a good option for MTL though. Maybe a 1.2ohm build of 3mm 28awg Kanthal and vaped at 15 to 20W say. I'll try all this over the course of the week and report back.
It's nice in it's current form (9% straw, 2% tangerine), but a very strong strawberry presence as you'd imagine.
Can you see if the RBA it works in the atlantis/atlantis 2? I want to get one for my beast.. they all should be the same coil.
Thanks
