***The Vapers Lounge*** 2.0
Status
Not open for further replies.
It doesn't. Well it won't in mine anyway.
The Atlantis coils have a screw thread on the top of the coils that keeps the tank section attached to the base. The Triton RBA is just smooth as it uses a different method to keep the tank attached.
The reason the Triton coils work in the Atlantis and vice versa is that all of the coils have the screw thread on them. The RBA does not.
Thanks.. The beast uses the threads on the tank and not the coil - IIRC... so the RBA will work on the beast but if it won't lung hit there's little point of me getting it, I would have to assume I have better MTL RTAs already.. :)
Wow!
Just done the DIY Key Lime Pie mix, my god it's strong! Might have to dial the Lime back a touch, nice to vape though, very clear flavours.
Also tried Rilots Sugarbear clone, yummy! Gonna let that badboy steep for a couple of weeks!
Not keen on my lemo 2.... might sell it and get a goblin mini - thoughts?
Also, got a dripper running @ 40w, but I can kill my coolfire 4 (2000mah) in about 2 hours so thinking of getting a dual 18650 mod. Any opinions on the IPV3, IPV4S, Sigelei 150w (should I wait for the 150w TC?) or the Xcube 2?
I love my sigelei 150 if you don't mind the size its cracking. the new 150w TC is so ugly!!
The snowwolf is another big mod tad more expensive. You see a lot of people selling sig 150/100+ mods for nice and cheap if you don't mind second hand
and theres all the new isticks coming out soon?
Wow!
Is this the 5% TPA Key Lime + 5% 1o1 Sugar butter cookie?
It will lung hit but not at power even remotely close to that which the stock 0.4 coils will take. It's a bit pointless for me too really. If I want a good MTL with defined throat hit then I pull out the Silo, KF4 or KFL. All of those are superior MTL than the Triton for me.
I've not tried the 1.8 ohm coil yet though. By all accounts it makes it an excellent MTL tank.
Wow!
Which recipe did you use Josh? I'd like to see the concentrates you used!
Try this simpler one which I've been vaping and it's delicious. The Cheesecake Graham crust is superb.
2% TFA Cheesecake Graham Crust
1% FA Vienna Cream
1% FA Lime Cold-Pressed
Use http://vapingunderground.com/forums/diy-e-liquid-recipes.50/ for your recipes guys.
Anything by HIC (HeadInClouds) is mostly all FlavourArt so completely Diacetyl, Acetoin & Acetyl Propionyl free!
Looking to get a starter kit, £40/50 budget. Leaning towards 0mg for flavours as since quitting im finding im missing the habit and eating instead.
Any recommendations for a complete noob and what flavours you recommend? (0mg)
Really hard to recommend flavours as its so subjective. There's juice my mates use as ADVs which i think tastes like burnt plastic. What sort of things do you like, fruits, custards etc?
Got a Triton with some 1.8 coils on order to use as MTL. Will do a quick write up once it arrives. From what i've heard it's awesome using MTL with those coils. :)
Id like the smallest one possible, but I guess they are much of a muchness?
Anyone know of a nice drip tip i presume u call em that, the bit u vape from that isnt metal and is well made and nice to use. As i have a evod2 one and that is too big, the nautilus mini, i havent had a go yet but i dont think id like the metal on it. So something none metal.
Ideas of which ones are out there and recommendations?
I bought the Wismec, seems fab. He gave me some free 0gm samples but they are all tea based...
Really fancy the custard flavours or a strong mint/menthol?
FA Custard 1%
FA Vienna Cream 1%
FA Lime Cold Pressed 2%
FA Lemon Sicily 2%
FA Pie Crust 1.5%
It's nice, but a little tort for me as the moment, going to have a play, might add some more cream to dilute the trotiness.
FA Custard 1%
FA Vienna Cream 1%
FA Lemon Sicily 2%
FA Pie Crust 1.5%
Ahaa, that's a recipe from Vaping Underground I posted a couple pages back.
Leave it for a week or so and it all mellows out. Maybe up the Pie Crust to 2%.
Just seen a review of the ipv d2... Does look impressive.. Looks nice too.. First ipv I've every said it about..
Never been a fan of Pinoneer 4 u, ain't they the smaller sister company of another company?
Edit: look like a stratum... But for £45 pounds.. Just wow..
Status
