I'm going to be re-spraying a bit of plastic that holds things like keys, coins, etc. It's a centre armrest cubbyhole. It has had it's day and a 5 min respray should make the eye sore go away (boom, I should be a rapper).
It's only a few bolts until it's out of the car so not spraying it in the car.
My question is, typical spray paint from Halfords probably won't be very resilient against keys and what have you. It will start chipping/scraping/scratching fairly fast. So, what other options do I have?
Painted everything, door cards, dash, plastic panels, headlining, it even worked on the steering wheel.
