What spray paint for resiliency on plastic
1 Dec 2006
Amsterdam, NL
I'm going to be re-spraying a bit of plastic that holds things like keys, coins, etc. It's a centre armrest cubbyhole. It has had it's day and a 5 min respray should make the eye sore go away (boom, I should be a rapper).
It's only a few bolts until it's out of the car so not spraying it in the car.
My question is, typical spray paint from Halfords probably won't be very resilient against keys and what have you. It will start chipping/scraping/scratching fairly fast. So, what other options do I have?
When I wanted to freshen up some aged black plastic on my Corrado door trim I lightly sanded it, used primer specifically for plastic, a black topcoat again for plastic and then a clear varnsh. It look like new several years later. The varnish will make it a little shiny though.
