100w Isticks on Fast tech
https://m.fasttech.com/products/1/10011027/2986100-authentic-eleaf-istick-100w-variable-voltage
Tempted as a cheap throw around mod, not sure I trust Isticks though
Interesting, I posted earlier about replacing my damaged 50w Istick, this works out around the same price as the Istick 50 minus the batteries so could be an alternative since I cant even find a release date for the P4U IPV D2.
As I said already the only issue iv had with my Istick 50 is that lately it has been a little temperamental with wattage and self adjusts when im not looking, it can drop around 7 watts but today it went from 23.8 to 25.5 on its own, clever little bugger lol.
I've just ordered a Kanger Subbox mini with subtank mini anyway as it got good reviews and I think I'll try this sub ohm malarky.
Just picked up a Triton & some Charlies Chalkdust, from my local B&M.
Going to be fun cleaning the tank out
Any idea who has the rebuildable deck in stock?
Cheers all
Ok, I've been a smoker for last 25 years.. rollies last 10 I guess.. damn that Golden Virginia!!! In a dilemma, I have about weeks worth of baccy left, (folks live abroad so nice 10 pack bales with reasonable frequency!)but, no baccy on the horizon, and wanting to go the vape route for some time.. I need your expertise... right I smoke maybe 20-30 a day.. ideally I want a menthol smoke, not mad peppermint.. more a spearmint.. (less harsh) smoke if possible.. something that makes the mouth feel 'cleaner'? I'm pretty good at technical stuff.. used to use a vapo LS for example.. can someone spec me a nice vape unit, and somewhere to buy the liquids? budget is up to 100 bucks.. thanking you kind sirs in advance![]()
yeah sorry for not reading .. but 200+ page thread is a tad off-putting.. what are the main parts I need.. the last post talks about several different 'bits', can you buy a unit and away you go? or is it that customising gives a better 'smoke' ?
yeah to stop you wasting cash, you really want a battery device (mod) with adjustable power, and an atty with adjustable airflow... so you can customise the vape production to suit your needs. At first stick to the factory made coils so you will learn what the vape should be like and then you have experience to make your own coils.
Really the istick 50w or the istick tc 40w is more than you need. The button can be a bit iffy on the 50w one but it's considered as a throw away item.. it should see you for the first 6-12 months.. most people have/had one as a everyday basher.
Tank wise adjustable airflow is king.. there is a certain range of airflow for each tank that is adjustable thou. some people like really tight vapes and some like airly vapes.
With both being adjustable, you should be able adjust the vape to your needs... normally and istick 50w, set at 17ish watts with a 1.6 ohm coil on a silo is a great setup and mainly experience users that have high end devices (that cost £100s) still use it from time to time.
You will need to adjust them to suit the juice and time of day.
Juice wise, try RY4 which is a sweet baccy flavour or there's plenty of baccy menthol and fruit menthol about... juice can be as cheap as £1 per 10ml bottle or stupid prices, normally high end juices are consider about £0.50p per 1ml.
Best thing is to think what fruit you like and by some juice of that flavor.
With you being a heavy rollie smoker, start on 18mg or higher.![]()
damn I'm lazy.. whereabouts are you getting your juice? So i need a unit like the istick and an atomiser.. obviously some juice too.. then I'm good to go? I ideally want a unit that won't blow up!!! (that's the main concern from the missus.. lol birds and newspapers eh? always a bad combo!)thanks for your reply.. do you have any links?damn I'm lazy.. whereabouts are you getting your juice? So i need a unit like the istick and an atomiser.. obviously some juice too.. then I'm good to go? I ideally want a unit that won't blow up!!! (that's the main concern from the missus.. lol birds and newspapers eh? always a bad combo!)
Again thanks all for the advice.. and lol @ how many damn flavours there are.. I could have a juice for every hr of the day!!! Something I was going to ask.. how often do you clean/change the atty? and how?Thanks for all the advice.. I'm thinking maybe going the istick 40, what sort of atty should I get? Is it worth paying more, like 30 bucks? I just want a nice smoke.. but like computers.. it's always nice to have headroom to tinkerAgain thanks all for the advice.. and lol @ how many damn flavours there are.. I could have a juice for every hr of the day!!! Something I was going to ask.. how often do you clean/change the atty? and how?
