Tyre Damage - Is it ok?
I would replace it - probably not too terrible but I'd rather know the car was solid rather than worrying it was about to blow a tyre. Also the pressure looks a little low (may be wrong, esp if its the front).
I see what you mean... even with that camera angle, it looks really low as you would expect the writing to be easily showing... that photo makes the tyre look under 15psi... so maybe the rubber chunk caused a leak?
Just to update the thread with conclusion, got it replaced this morning just to be safe.
Good news... make sure you check your tyre pressure every two weeks.
