The GTX Titan X owners thread.
Anyone gone over to Windows 10, any issues with card(s), how is performance?
I think there is some issues with SLI but for a single card, none thus far. I can't say I have seen any improvements and maybe a bit of a drop off but quite happy overall.
Well. I've just realised I've bought one for a 980! I don't remember asking for a reminder for that!!
Looks like my 980 in my SteamOS machine will be getting an AIO :)
If it's the EVGA 980 hybrid cooler it fits the Titan X, only difference is the shroud says 980 instead of Titan X.
I have the 980ti hybrid cooler on my Titan X.
Yeah I've got two of the 980 hybrids on my Titan X's.
They didn't do a TitanX shroud at the time I bought it :)
Great. Looks like I'll have to buy another Titan after all ;)
SLI is working as normal for me in Windows 10 with Titan X SLI.
Has been through most of the tech preview as well to be honest.
+1 but tbh honest I've switched it off for now 1 of them chomps through everything butter smooth @1440p finally! Guess I'll save it for a decent 4k g-sync hopefully round the corner!
So after flashing my bios I'm happy with the extra performance and think this is the way I want to run my card 24/7 but temps get up to 84c which I believe it is ok on stock cooling but everything's very loud now and I'm a little worried about the VRam temps.
So who would recommend the Hybrid EVGA cooler?
What would this bring my 84C max temp down by and the noise? Will it help Vram temps?
Also where should I fit it in my case? A B or C? I have a H100i cooler strapped to the top of the case so it can't go there.
And are they out of stock everywhere?
