Caporegime
- 8 Jul 2003
- In a house
I saw that mate, didn't think it would be much of a drama tbh![]()
Should be cracking in Xfire
I just spent a few hours playing games with stock clocks, I spent time on the Bf4 campaign, Dying Light and Crysis 3 and real temp recorded a max of 53 degrees for the Sapphire Fury Tri-X. Earlier on a ten minute Furmark stress test with an 1100 overclock only reached 56 degrees. Plus it's silent, Coming from a 94 degree MSI 290x gaming I'm very happy.
A few comparison benches for the 290x Gaming and Fury Tri-x.
Gamename, 290x, Fury, min/avg/max
Fc2 115/156/240, 118/152/239,
Sleep Dog 37/52/63, 43/62/76,
Hitman Abs 46/57/182, 52/65/80,
Tomb Raider 64/87/114, 78/101/128,
Alien Iso 4/111/239, 5/127/180,
Res Evil 6 14307, 15876,
Apart from Far cry 2's bench where the 290x wins the Fury managed an okay lead but it wasn't massive and it make me wonder where the 390x fit's in here, I've got another 6 benches to test but they not that important really for me the switch was a massive win thanks to the improvements between temps and noise.
Although not cheap I'm very happy with the Fury and I'm glad I got it to replace Hawaii.
Is this at 1080p? Its a decent boost but the difference will be more clear at higher resolution. You should try at 1440p.
The lights on the card are blue, Can they be changed?
Nevermind, They can.
Yes you can, there are very two small TINY switches to the just slightly to the left from the load lights. You can switch them to Red, Blue, Purple of off.
EDIT, noticed you edit![]()
Same here, I've got a Rog Z97 hero board that glows red and a couple of those quiet edition red led Corsairs fans OCUK did dirt cheap a while back, The blue was looking out of place, It looks better nowCool thanks. Gotta be red has it.
Cracking temps those, my 290 at 1080 hits around 85/86 at 1440p, odd game hits 88, on auto fan, if i get temps like that on a Fury, be no bother with 2x.![]()
Running Fur marks stress test with no AA has it hitting 63 degrees and with the 1 for 1 fan profile I can hear the fans then, There not overly loud though, I'm going to adjust my fan profile and aim for a temp target of around 75 degrees max.
I'm still interested to see your far cry 4 results btw since that's what you said was chugging on the 290x and I know the difference will be huge there.
Far cry 4's running great, The 290x's performance was between 30 and 40 at 1080p while the Fury does the same settings between 70 and 80 at 1440p.
I'll actually get to play it now.
Great improvement that, faster at a higher res![]()
Ooh.
