There is no screen on them
5930k.......... for the extra pci-e lane
MSI X99S SLI Plus Intel X99 ....................as its the best midrange x99 board
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-25600C16 3200MHz Quad Channel Kit............. because well its 3200mhz
Samsung SM951 256GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive ............... because well its fast!
Seagate 2TB SATA-6Gb 7200rpm 64MB
Corsair Hydro H100i GTX 240mm High Performance Liquid CPU Cooler
SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - Black..... this it an amazing psu could even power 3x290's as 8 pack found
2x Zotac GeForce GTX 980Ti "Reference Design" 6144MB
Acer Predator 4k2k XB280HK 28" G-Sync................ for a fluid 4k experience
comes in at 2800inc vat so 200 for case and any other bits you want
The Monitor isn't included in the budget.
You don't need a 1200W psu for SLI. Even a 1000W gives headroom.
The 5820K is fine for SLI and an M.2 pci-e SSD. You don't need the 5930K.
Also you don't need high speed Ram. A 2400MHz kit will do the same thing.
wow thanks for the help, now I have to go away and do some thinking![]()
But why spend more than you need too ? and if its future proofed you don't know what might take more pci-e lanes in future.
You are spending more by going with the 5930K when it isn't needed. There is no such thing as future proofing either.
but it gives him the option of a 3rd gpu later on if he wanted to
the gigabyte boards only use the m2 port @ 50% its stated speed though
buy the best you can afford I'm sure in 3 years to gpus will need full 16x 3.0 to run two smoothly
There is. My i7 920 was bought in January 2010 and if the motherboard/memory hadn't give up I would have still been using it now with my 970 GTX which (currently running with 8GB as it slowly dies) plays any game full setting 1920x1080.
But his budget allows for it then why not ? if you buy the best core components all you need to do is swap gpu's as they start to fall behind.
But years down the line like the old x58 systems they will still be able run and keep up with latest gen gpu's
