Help building my 1st PC
and what was your thoughts on the 980ti's vs titan x they perform with in a few % of each other the main selling point will be the vram are you planning to crack the settings high at that res like AA ?
There is no screen on them
5930k.......... for the extra pci-e lane
MSI X99S SLI Plus Intel X99 ....................as its the best midrange x99 board
Corsair Vengeance 16GB (4x4GB) DDR4 PC4-25600C16 3200MHz Quad Channel Kit............. because well its 3200mhz
Samsung SM951 256GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive ............... because well its fast!
Seagate 2TB SATA-6Gb 7200rpm 64MB
Corsair Hydro H100i GTX 240mm High Performance Liquid CPU Cooler
SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - Black..... this it an amazing psu could even power 3x290's as 8 pack found
2x Zotac GeForce GTX 980Ti "Reference Design" 6144MB
Acer Predator 4k2k XB280HK 28" G-Sync................ for a fluid 4k experience
comes in at 2800inc vat so 200 for case and any other bits you want
The Monitor isn't included in the budget.
You don't need a 1200W psu for SLI. Even a 1000W gives headroom.
The 5820K is fine for SLI and an M.2 pci-e SSD. You don't need the 5930K.
Also you don't need high speed Ram. A 2400MHz kit will do the same thing.
But why spend more than you need too ? and if its future proofed you don't know what might take more pci-e lanes in future.
You are spending more by going with the 5930K when it isn't needed. There is no such thing as future proofing either.
There is. My i7 920 was bought in January 2010 and if the motherboard/memory hadn't give up I would have still been using it now with my 970 GTX which (currently running with 8GB as it slowly dies) plays any game full setting 1920x1080.
I could buy an i7 4790K and 8GB Ram and it would perform just as good as an i7 5960X with 64GB Ram in most cases when gaming. You don't even need an i7 for a pure gaming pc.
But his budget allows for it then why not ? if you buy the best core components all you need to do is swap gpu's as they start to fall behind.
But years down the line like the old x58 systems they will still be able run and keep up with latest gen gpu's
The 5820K and 5930K will have very similar performance as they are both 6 core cpu's. The 5930K has a slightly higher clock speed of 200MHz and an extra 100MHz Turbo boost.
So you are paying roughly an extra £140 for the 5930K for a few more pci-e lanes and 200MHz clock speed. Not worth the extra money in my book.
I would only go with the 5930K if I knew I was going to utilize all the pci-e lanes. Most people will be fine with 28 lanes on the 5820K.
