PST: Project Silicon Talisman
22 Jul 2015
Aberdeen
Hi,
I am going to start a new build named PST: Project Silicon Talisman. I have received most of the parts and awaiting some. It is a combination of old and new parts. I am not upgrading monitor, CPU, motherboard and memory as there isn't much to gain with the Skylake over Haswell Devil's Canyon. The build consists of the following components:
CPU: Intel® Core™ i7-4790K Haswell Devil's Canyon
GPUs: 2x Sli Nvidia Galax/KFA2 GeForce GTX 980 Hall of Fame (HOF)
RAM: 16GB Corsair Vengeance Pro 2400MHz DDR3 (4x4gb)
Motherboard: MSI Z87-G45 Gaming
PSU: SuperFlower Leadex GOLD 1300W Fully Modular "80 Plus Gold" Power Supply - Black
Case: Phanteks Enthoo Luxe Full Tower Case - Black
Cabling: Custom cabling ordered to fit the red/white theme.
Watercooling loop:
Coolant: Mayhems Pastel Ice White
CPU Cooler: EK Water Blocks EK-Supremacy EVO
GPU Blocks by Diamond Cooling - White Acetal
14/10mm Acrylic Tubing
Barrows Black compression fittings
420mm Hardware Labs Black ICE Radiator GT Stealth 420 (Push+Pull)
360mm Hardware Labs Black ICE Radiator GTX 360 (Push+Pull)
Pumps: I am using two different pumps because I already own them and taking them off my existing loop
Pump 1: Swiftech MCP35X Industrial Pump 12 Volts
Pump 2: Swiftech MCP655-B Water Pump 12 Volts (EK-XTOP D5 Pump Top)
Radiator Fans:
420mm Rad: Push/Pull - 6x 140mm Akasa AK-FN063 Viper Fan High Performance S-FLOW Blade Quiet Fan - 3.12 mm/H2O
360mm Rad: Push - 3x 120mm Corsair SP120 High Performance Edition High Static Pressure Fan - 3.1 mm/H20
Pull - 2x 120mm Phobya G-Silent 1500rpm + 1x 120mm Cooler Master Fan
Thanks for watching. :)
REV01: Larger Side Panel Window and temperature display inside the case.
Original Build Photos
System turned ON
With Side Panel ON
Never heard of diamond cooling. Have you considered petg tubing rather than acrylic?
Diamond Cooling are doing waterblocks for only one particular series of cards and that is Galax Hall of Fame 980/970 and possibly 980 Ti also. I looked at PETG but reading around leaves a lot of question marks on it's compatibility with coolants and UV reactivity, etc.
Sounds like a fun build, looking forward to some pictures. I'm still out on petg, i've used acrylic before and never had an issue with it so don't see the need to change.
Working on the SLI bridge with the Galax Hall of Fame logo to compliment my gpus. I have received the bridge cover. Now this needs to go on to the bridge itself. Pictures to follow.
Hey Faheem, I recognised your name in your forum nickname :)
We are working on them buddy. Hang in there ;)
And of course good luck with your project!
Tim
Tim
Hey Tim ;) Great to see you here. Yes looking forward. Meanwhile I can keep myself busy with drilling a few holes in the chasis. A lot of little stuff to get out of the way.
First coat on the fan grills. These will go on the rear side panel, which will be cut to accommodate 3 140mm fans for air intake.
