I dont have a g-sync monitor but I do use SLI. I do not experience any flickering; neither on menus nor in game.
You wouldn't, it was a Gsync problem.
You're in the minority then. I did get the flickering issue on release but there's no stuttering o.O It's a good experience playing Witcher 3 at 4k for me, and I certainly don't struggle for 30 - most of the time I clear 60 and that's with everything but AA on ultra (and one of the vegetation viewing options, can't recall which).
Well that's what I would have expected but i'm certainly not the only one. I've read on other forums people having the same issues with stuttering. I have no idea whats wrong with it other than the drivers. It's fine when crossfire is disabled but obviously half the frame rate. Granted i'm on 290s not furys but still. It gets high fps when I put it on my 4k samsung monitor (60hz) but the stuttering makes it unplayable. It's even the same on 1440p. This is after a clean install of win10, 4.5ghz i7 and ssd. Other games like battlefield run fine in xfire tho.
Odd. Is Windows 10 the commonality between you and the others getting it? I run windows 7 and it's fine, it was fine (although not acceptable framerates) on my 7970s at 4k as well -- It was perfect at 1440p on my 7970 xfire, no stuttering just the flickering issue for the first week or so before driver update.
Drivers at 15.7.1? Tried earlier?
Any overlays running? Sometimes overlays, even the steam one, can cause issues.
Beyond that, I'm out of ideas for you D:
Does Crossfire work in this game? It might be worth getting a 2nd hand 290 for £180 as cheaper way of boosting performance.
They use just over 8gb of VRAM per card as the memory is mirrored.
A pair of 970s may struggle a bit at 4k.
For a pair of cards going from worst to best IMHO would look something like this below
GTX 970s, 290Ps, GTX 980s, 290Xs (4gb), 290Xs (8gb), Fury Ps, Fury Xs, GTX 980 Ti's
what psu do you have at the moment?
Jaggies are pretty much eliminated with smaller (<40") 4k displays, but they are not the only type of aliasing artefacts; thin objects like wires and hair exhibit pixel-popping without AA. It's not a big difference at 4k, but it still looks better with AA.I cannot notice any difference. You got really good eyes there
The whole point of AA isn't to smooth out the jagged edges? And a panel packed with 8M pixels hardly reveals them.
Is this the thread we chatted on this morning mate? I can't find all the posts we exchanged?
trust me I am not shooting from the hips
I owned a gtx 970 sli setup and tried all the latest games on it. You will do just fine at 4K with GTX 970 sli as soon as you turn the AA off (dont know why anyone will use AA at 4K). Plus for GTA5 you can turn down a few taxing settings like soft shadows and draw distance, etc. Rest can be pretty much combination of ULTRA/HIGH and that will keep you happy.
Why did you upgrade to 2x 980?
one of the 970 died and I was planning to do a new build anyway. otherwise my plan was to keep things this way for another year may be until next generation of cards come out.
Interesting. Because this gigabyte g1 gaming card is actually fast, another one would be 280... it has the same architecture as the 980. Now you have got me thinking. The bottleneck is the memory. But you say it's down to AA and 4k looks amazing in anyway without AA?
6gb is a bottleneck too, not at the minute but it will be.
So what games did you play in 4k with your 970gtx sli setup and what sort of fps did you get?
first thing don't sink yourself in this vram issue. at the moment it is more theory than actual world results. I played all the power thirsty games on 4K on gtx 970 sli (almost everything on ultra with AA off). Witcher 3 was just over 40fps with AA and hairworks off. Crysis 3 was pretty much the same. Farcry 4 stayed between 50-60fps. Tombraider around 60fps. All these are playable frame rates and no single card will do better than this. I overclocked my cards and I am confident that no single card beats a 970 sli setup at any possible resolution. You will want to buy a 980 ti or titan x at the moment only if you want to pick up another one down the line to sli. otherwise you will live with overall inferior performance to 970 sli. 970 sli is cheaper option for you because you already own one. but again that is assuming that games you play have good driver support for sli.
2-Way Sli Gtx 970
Firestrike
http://www.3dmark.com/fs/5014740
SCORE
17927 with NVIDIA GeForce GTX 970(2x) and Intel Core i7-4790K
Graphics Score 24330
Physics Score 13560
Combined Score 7198
Skydiver
2-way sli gtx 970
http://www.3dmark.com/sd/3094461
SCORE
39927 with NVIDIA GeForce GTX 970(2x) and Intel Core i7-4790K
Graphics Score 76614
Physics Score 13505
Combined Score 24102
Thank you.
There is also the possibility that future games will also be programmed to take advantage of multiple GPUs(including memory) using Direct X 12.
Would a Corsair 850 WATT handle 2 of the cards?
Yes 850 watt is enough for 2 way 970 sli. And I hope that dx12 improves things further.
