Is there going to be a case compatibility list?
EKWB are releasing a case compatibility list soon.
Interested to see how it would compare to the Kraken.
How soon before we see a Predator 360 review? Is there going to be a case compatibility list?
Looks expensive compared to aio coolers but this are almost custom loops I bet the parts separately won't be cheap either!
To buy the products included in the 240 Predator [which wouldnt be an all in one pump unit with the rad so you would need a reservoir or fill port anyway]
CPU Block - 34.99
RAD - 59.99
Tubing - 3.49
Fittings - 15.16
DDC Pump - 54.98
Coolant - 5.60
Fans - 23.98
Total 198.19
So realistically, the Predator unit is very cheap for what it is.
I have asked EK to see if they have any updates on this but I can't imagine it is the sort of info they will have to hand yet.
tough one, the rad is a modified version of CoolStream PE so I guess it just uses the screw mounts off that.
In honesty though, I have an EK Rad from years ago that has been installed in about 20 different setups and had countless screws put into the fan mounts without any threading issues.
It's only true rival is the Swiftech, be interesting to see how they fare against each other rather than the cheap aio kits.
I guess my silver arrow has ruined me to ever jump to watercooling cause it's so quiet, with the fans running at around 300-500rpms it will always be quieter than water cooling as it's unlikely pumps will ever drop to something that .
£100 extra over what I paid for my triton for 2c. Lmfao must be having a laugh.
... is it really worth saving the £30 over a proper custom loop when you have to have the weird res/pump unit and that gawdy tubing/connector?
Still, looks like a decent cooler if you are interested in a custom loop. Although I would rather just build my own and not be stuck with what EK give me. You shouldn't be worrying about costs with custom loop (to a certain extent obviously), since they are purely a luxury anyway, why settle for something other than exactly what you want? Still a great product if this is EXACTLY what you want though, but seems like incredibly niche.
I got my triton because it has the possibility of expansion if I wish it in the future, but it was also VERY cheap compared to pretty much every AIO out there. This on the other hand is so expensive, that you would have to be pretty insane to not expand it. But by that time, is it really worth saving the £30 over a proper custom loop when you have to have the weird res/pump unit and that gawdy tubing/connector?
