You realize a snapped coil spring is potentially dangerous?
Why not change them regularly before they fail then? Just to be extra safe.
Often if one goes the other is very close behind.
When my front left one cracked at the base I place an order for some new front springs, whilst waiting for delivery the other front one cracked.
Thats clearly a guarantee that every time a spring snaps, nothing bad will happen at all
Meh, I've been passenger in a car when the front left spring went through the tyre at speed. Wasn't that dramatic tbh, inconvenient that we couldn't get the jack under with a flat tyre and half a spring though.
Following that logic the OP should probably replace all 4 !
i have driven a car with just one spring replaced couldn't tell the difference.
front one as well.
Good to see cars are built down to a price, not up to a quality these days. Snapped springs used to be rare, now it's normal![]()
It's got absolutely nothing to do with being able to "tell the difference"![]()
If it makes no difference to the handling or stability of the car, then why are you insisting it's so important?
Yes, he's replacing the snapped one...
