**** The Official Note 4 thread ****
Just straight upgrade. No need to do a factory reset from 5.0.1 to 5.1.1 and yeah its the Italy one.
https://drive.google.com/file/d/0B0UrwVKY4D5jWHlQcjBPY2x6U1E/view
I Just downloaded this... Flashed it on the computer with Odin and was good to do. Pretty simple.
when you flash this, the CSC gets blanked which kills the S-Pen features
you need to reflash the CSC files from here: http://forum.xda-developers.com/showpost.php?p=62575684&postcount=42
using ODIN, select AP etc, takes 30 secs.
I still have the Note4, feel kinda stuck with it.
The battery life is terrible. It lags more than is acceptable. It crashes a lot.
Sorry to hear that.
Which version do you have. I have the F & just got the C & installed the 5.1.1 & boy the Note 4 is like different beast. No lag or stuttering.
Maybe the 5.1.1 update will help the F but if you can hold of the C (exynos) version grab it with both hands. It a cracker.
You were right about S-Note (although the pen worked, it just wouldn't open)
Thanks for the link.
I'll be giving the battery a good test over the next 24 hours.
