- 22 Jul 2014
- Oxon
Any problems or drops with connections running over Homeplugs will be down to naff wiring in your home (old, separate circuits, etc).
Apart from the price and a slight difference in part number i wonder what the difference is between these and the £15 cheaper TL-PA8010PKIT set at the guys in purple?
Looks like you just get 1 LAN port with the cheaper model. Not bad if you're just hooking upto a media centre![]()
I've not had any problems with these for gaming yet, may sound bias as I am staff, but I have this exact pair, and I play CS:GO constantly on them with no drop outs, lag or any other inconveniences.
Are you talking about these particular sets? Or is it a different model that you had before?
Not trying to dump on the thread, but in the interests of accuracy and fairness, in my experience, these really are not suitable for gaming. General web browsing and downloads perhaps, but they drop the connection far too frequently to rely upon. A wired connection or wireless would be better.
Actual data transfer rate will vary from network environment including: distance, network traffic, noise on electrical wires, building material and construction, quality of electrical installation and other adverse conditions.
My home is 11 years old, the wiring is fine. I've had it checked by our electrician and the study is on the same ground floor loop as the router. When connected by PLAs, the connection would randomly drop, forcing me under my desk to switch off and on the PLA. Sometimes four or five times a day or more. Unacceptable.
I'd be interested to learn what differences exist between the homes of those for whom it works and mine where it doesn't.
They're perfect for gaming in my experience, pings similar to being connected directly with ethernet cable but without the hassle of having to actually run said cable. WiFi tends to be far more temperamental.
