Man of Honour
- 17 Nov 2003
- Southampton, UK
Instead of posting the article (which you will probably say has an anti-immigration bias), I will post the sources cited in the article.
If you google "77.6 percent rape sweden" you will find it has been copied around and reposted everywhere. That in itself does not prove anything, but there is plenty of opportunity for it to be debunked or challenged, and not much of that going on.
Unless you speak Swedish it might be hard to verify.
Apparently (you would probably be able to confirm this) sometime after the 2005 report they stopped recording nationality of offenders, or stopped publishing this data. So more up-to-date reports can never be made. A lot of people are saying this is a deliberate attempt to cover it all up.
I was after links to primary sources not citations.
Having done a bit of Googling and I found what looks to be the 2005 report that you mention. https://www.bra.se/download/18.cba8...bland_personer_fodda_sverige_och_utlandet.pdf
From reading this through Google Translate, I can say that I'm unsure of the validity of that statistic. What I did find is that all the statistics refer to suspects rather than convictions which could be significant or it could be mistranslation or it could be an intricacy of the Swedish criminal justice system. I wouldn't trust the statistic without further information though.
The topic of Swedish immigrant rape is a hot topic.
