I decided the GTX960 wasn't powerful enough as I want the latest version of this build to last a while so I picked up one of these -
It needs a bit of modification - not happy with the bright green "GEFORCE GTX" logo and if I'm voiding the warranty to do that I might as well change the silver to white
I've also got some white RAM sticks turning up today and I'm getting very impatient waiting for OCUK to get a white Cablemod kit in so I can get everything finished.
I'm also pondering the front of the case as the front grill doesn't fit quite right at the moment. I may remove the grill and replace it with some sort of custom job - it could end up just being fan guards though!
Board went bad and got RMAd, I've got a new one so I've given things a bit of a spruce up when fitting it.
First of all, I decided I hated the green "GEFORCE GTX" so much I couldn't cope with it anymore. And whilst I was at it I got the white spray paint out again. Clearly I've not learned my lesson yet
It does look AMAZING now though -
No more green light!
And credit to MSI and Kingston - these 2 looked damned sexy together -
It's actually a piece of moulded rubber with green paint on. You can pop it out and sand the paint off. It looks black/grey when it's off but it's actually clear so the LED shines white through it when it powers on
I think some of the newer cards have moved to coloured rubber/plastic but the older ones should all be painted clear rubber.
