Anyone know how much a body shop would charge to sort it? I wouldnt want them to re-spray the whole roof.
If you're considering changing coolant anyway then look at doing any preventative work you think is worthwhile in the system at the same time. The coolant itself can often be one of the most expensive oarts
OK, what is the best way to flush the system though?
