Hi there
Samsung's super-fast and vastly cheaper than the Intel 750 series are now available, the AHCI models are all in stock and reduced in price with the even faster NVME models arriving tomorrow:-
Samsung SM951 128GB M.2 PCI-e Gen3 8Gbps x 4 AHCI Solid State Drive (MZHPV128HDGM-00000) @ £67.99 inc VAT
The SM951 boasts outstanding performance, supporting both PCIe 3.0 and PCIe 2.0 interfaces. They can read and write sequentially at 1,600 MB/s (megabytes per second) and 1,350 MB/s respectively based on PCIe 2.0. This performance level is approximately three times faster than that of the latest SSD with a SATA interface and about 30 percent faster than that of the Samsung XP941, its predecessor. In addition, the new SSD's random read and write speeds reach up to 130,000 and 85,000 IOPS (inputs / outputs per second) respectively.
For ultra-slim notebooks and workstations wanting to adopt the PCIe 3.0 interface, the SM951 can read and write sequentially at 2,150 MB/s and 1,550 MB/s respectively, which would provide approximately four times faster sequential reading performance compared to current SATA SSDs. With a PCIe 3.0 interface, the drive achieves substantially higher energy efficiency, requiring only about 450 MB/s per watt for sequential reading and 250 MB/s per watt for sequential writing, which translates into a more than 50 percent improvement in performance per watt over that of the XP941 SSD.
In addition, the SM951 is the first SSD to adopt the L1.2 low power standby mode (which allows all high-speed circuits to be turned off when a PC is sleeping or in hibernation) as defined by PCI-SIG (the PCIe standards body). By embracing the L1.2 level of standby operation, the SM951's power consumption is drastically reduced – to under 2mW, about a 97 percent decrease from the 50mW consumed using a L1 state.
Samsung's SM951 comes in the M.2 form factor (80 mm x 22 mm), which is only about one seventh the size of a 2.5" SSD. Also, it weighs approximately six grammes. The drive's compactness is well suited for most notebook PC designs, freeing up space for other components including the battery. The SM951 lineup consists of 512, 256 and 128 GB SSDs.</p>
NOTE: Some M.2 motherboards only support SATA 6Gbps speeds or PCI-e x 2 lanes. You need to make sure your board supports PCI-E x4 Lanes to get the full speed from this SSD.
Specification:
- M.2 PCI-E 3.0 (x4) interface or M.2 PCI-E motherboard slot
- MLC NAND
- Read Speed: 2000MB/s
- Write Speed: 600MB/s
- IOPS: 140k/40k
- Warranty: 2yr
Was [£68.99] Inc. VAT
Only £67.99 inc VAT.
ORDER NOW
Samsung SM951 256GB M.2 PCI-e Gen3 8Gbps x 4 AHCI Solid State Drive (MZHPV256HDGL-00000) @ £119.99 inc VAT
Specification:
- MLC NAND
- Read Speed: 2150MB/s
- Write Speed: 1200MB/s
- IOPS: 140k/80k
- Warranty: 2yr
Was [£149.99] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Samsung SM951 512GB M.2 PCI-e Gen3 8Gbps x 4 AHCI Solid State Drive (MZHPV512HDGL-00000) @ £229.99 inc VAT
Specification:
- MLC NAND
- Write Speed: 1500MB/s
- IOPS: 140k/85k
- Warranty: 2yr
Was [£299.99] Inc. VAT
Only £229.99 inc VAT.
ORDER NOW
Samsung SM951 128GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive (MZVPV128HDGM-00000) @ £85.99 inc VAT
The new, best thing in storage technology, NVMe, which has been hot property in the server market due to it's extreme transfer speeds, has now reached the desktop market. The Samsung SM951 M.2 PCIe NVMe SSD is the new performance leader in M.2 form factor SSD's. Providing up to 2000MB/s read and 650MB/s write sequential data transfer rates, along with astounding random I/O ratings of 300k reads and 83k writes.
The Samsung SM951 (NVMe) is compatible as a boot device in a wide variety of systems with a free PCIe 2.0/3.0 M.2 socket. This includes Z170/Z97/X99 based motherboards, modern notebooks, and tiny form factor PC's like the Intel NUC. It can also act as additional super high speed storage in almost any desktop with a spare PCIe slot when combined with a PCIe adapter.
Key Features:
- Extreme performance - up to 2000/650 sequential read/write data transfer rates and 300k/83k read/write random IOPS
- Bootable in Windows 7/8, Mac OSX (2006-2010 Mac Pro only) and Linux
- PCIe 3.0 device, backwards compatible with PCIe 2.0
- Small M.2 form factor plugs straight into your PCIe-based M.2 socket with no additional cables required
NOTE: Some M.2 motherboards only support SATA 6Gbps speeds or PCI-e x 2 lanes. You need to make sure your board supports NVMe and PCI-E x4 Lanes to get the full speed from this SSD.
Specification:
- M.2 PCI-E 3.0 (x4) interface on an NVMe Compatible Motherboard
- MLC NAND
- Write Speed: 650MB/s
- IOPS: 300k/83k
- Warranty: 2yr
Was [£89.99] Inc. VAT
Only £85.99 inc VAT - Arriving Tomorrow!
ORDER NOW
Samsung SM951 256GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive (MZVPV256HDGL-00000) @ £155.99 inc VAT
Specification:
- MLC NAND
- Write Speed: 1260MB/s
- IOPS: 300k/100k
- Warranty: 2yr
Was [£179.99] Inc. VAT
Only £155.99 inc VAT - Arriving Tomorrow!!
ORDER NOW
Samsung SM951 512GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive (MZVPV512HDGL-00000) @ £289.99 inc VAT
Specification:
- MLC NAND
- Write Speed: 1550MB/s
- IOPS: 300k/100k
- Warranty: 2yr
Was [£329.99] Inc. VAT
Only £289.99 inc VAT - Arriving next Monday!!
ORDER NOW
Intel 750 Series 400GB PCIe 3.0 X4 HHHL Adaptor NVMe Solid State Drive (SSDPEDMW400G4X1) @ £299.99 inc VAT
The Intel SSD 750 Series is Intel's first PCIe* Gen3 x4 SSD developed for the client enthusiast and workstation markets. The Intel SSD 750 Series is architectured with the new high performance controller interface - Non-Volatile Memory Express* (NVMe') - delivering outstanding performance, low latency and Quality of Service. NVMe is a standardized interface that enables higher performance and lower latency than previous generations. The Intel SSD 750 Series offers capacities of 400GB and 1.2TB in Add-ln card and 2.5-inch (SFF-8639 connector) form factors.
The Intel SSD 750 Series is Intel's highest performing client drive specifically designed for the PC enthusiast and Workstation systems with demanding storage workstation requirements. Wth PCIe Gen3 x4 support and NVMe queuing interface, the Intel SSD 750 Series delivers excellent sequential read performance of up to 2.4 GB/s and sequential write speeds of up to 1.2 GB/s. The Intel SSD 750 Series delivers random read IOPS of up to 440K and random write IOPS of up to 290K for 4KB operations. Also, by taking advantage of the direct path from the storage to the CPU by means of NVMe, the Intel SSD 750 Series exhibits low latency of less than 20 ps for sequential access to the SSD.
Features:
- PCIe Gen3 x4 with NVMe interface
- Half Height Half Length (HHHL) Add-in-Card
- Consistently Higher IOPS and throughput
- Sustained low latency
- Enhanced power-loss data protection
- Temperature Monitoring and Logging
- End-to-End Data Protection
Specification:
- Capacity: 400GB
- Form Factor: HHHL Half Height PCI-E
- Interface: PCI-E 3.0 (x4)
- Host Controller: NVMe
- Flash Type: Intel 20nm MLC NAND
- Max Read: 2200MB/s
- Max Write: 900MB/s
- Max IOPS (Random Read 4k): 430,000
- Max IOPS (Random Write 4k): 230,000
- Warranty: 5yr
Was [£319.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Intel 750 Series 800GB PCIe 3.0 X4 HHHL Adaptor NVMe Solid State Drive (SSDPE2MW800G4X1) @ £549.95 inc VAT
Features:
Specification:
- Capacity: 1.2TB
- Max Read: 2100MB/s
- Max Write: 800MB/s
- Max IOPS (Random Read 4k): 420,000
- Max IOPS (Random Write 4k): 210,000
- Warranty: 5yr
Was [£599.99] Inc. VAT
Only £549.95 inc VAT.
ORDER NOW
Intel 750 Series 1.2TB PCIe 3.0 X4 HHHL Adaptor NVMe Solid State Drive (SSDPEDMW012T4X1) @ £799.99 inc VAT
Features:
Specification:
- Capacity: 1.2TB
- Max Read: 2400MB/s
- Max Write: 1200MB/s
- Max IOPS (Random Read 4k): 440,000
- Max IOPS (Random Write 4k): 290,000
- Warranty: 5yr
Was [£829.99] Inc. VAT
Only £799.99 inc VAT.
ORDER NOW
Elite Tier SSD's for those who want the best in SSD technology, insanely fast, definitely Elite Tier hardware !!!!
View Our Full SSD Range - Click Here!
Specification:
- MLC NAND
- IOPS: 140k/40k
- Warranty: 2yr
ORDER NOW
Specification:
- MLC NAND
- IOPS: 140k/80k
- Warranty: 2yr
ORDER NOW
Specification:
- MLC NAND
- IOPS: 140k/85k
- Warranty: 2yr
ORDER NOW
Key Features:
Specification:
- MLC NAND
- IOPS: 300k/83k
- Warranty: 2yr
ORDER NOW
Specification:
- MLC NAND
- IOPS: 300k/100k
- Warranty: 2yr
ORDER NOW
Specification:
- MLC NAND
- IOPS: 300k/100k
- Warranty: 2yr
ORDER NOW
Features:
Specification:
- Capacity: 400GB
- Warranty: 5yr
ORDER NOW
Features:
Specification:
- Capacity: 1.2TB
- Warranty: 5yr
ORDER NOW
Features:
Specification:
- Capacity: 1.2TB
- Warranty: 5yr
ORDER NOW
