** SAMSUNG M.2 PCI-E Super-Fast AHCI & NVME SSD's IN STOCK (ELITE TIER SSD's)!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Samsung's super-fast and vastly cheaper than the Intel 750 series are now available, the AHCI models are all in stock and reduced in price with the even faster NVME models arriving tomorrow:-
Samsung SM951 128GB M.2 PCI-e Gen3 8Gbps x 4 AHCI Solid State Drive (MZHPV128HDGM-00000) @ £67.99 inc VAT
The SM951 boasts outstanding performance, supporting both PCIe 3.0 and PCIe 2.0 interfaces. They can read and write sequentially at 1,600 MB/s (megabytes per second) and 1,350 MB/s respectively based on PCIe 2.0. This performance level is approximately three times faster than that of the latest SSD with a SATA interface and about 30 percent faster than that of the Samsung XP941, its predecessor. In addition, the new SSD's random read and write speeds reach up to 130,000 and 85,000 IOPS (inputs / outputs per second) respectively.
For ultra-slim notebooks and workstations wanting to adopt the PCIe 3.0 interface, the SM951 can read and write sequentially at 2,150 MB/s and 1,550 MB/s respectively, which would provide approximately four times faster sequential reading performance compared to current SATA SSDs. With a PCIe 3.0 interface, the drive achieves substantially higher energy efficiency, requiring only about 450 MB/s per watt for sequential reading and 250 MB/s per watt for sequential writing, which translates into a more than 50 percent improvement in performance per watt over that of the XP941 SSD.
In addition, the SM951 is the first SSD to adopt the L1.2 low power standby mode (which allows all high-speed circuits to be turned off when a PC is sleeping or in hibernation) as defined by PCI-SIG (the PCIe standards body). By embracing the L1.2 level of standby operation, the SM951's power consumption is drastically reduced – to under 2mW, about a 97 percent decrease from the 50mW consumed using a L1 state.
Samsung's SM951 comes in the M.2 form factor (80 mm x 22 mm), which is only about one seventh the size of a 2.5" SSD. Also, it weighs approximately six grammes. The drive's compactness is well suited for most notebook PC designs, freeing up space for other components including the battery. The SM951 lineup consists of 512, 256 and 128 GB SSDs.</p>
NOTE: Some M.2 motherboards only support SATA 6Gbps speeds or PCI-e x 2 lanes. You need to make sure your board supports PCI-E x4 Lanes to get the full speed from this SSD.
Specification:
- M.2 PCI-E 3.0 (x4) interface or M.2 PCI-E motherboard slot
- MLC NAND
- Read Speed: 2000MB/s
- Write Speed: 600MB/s
- IOPS: 140k/40k
- Warranty: 2yr
Was [£68.99] Inc. VAT
Only £67.99 inc VAT.
ORDER NOW
Samsung SM951 256GB M.2 PCI-e Gen3 8Gbps x 4 AHCI Solid State Drive (MZHPV256HDGL-00000) @ £119.99 inc VAT
Specification:
- MLC NAND
- Read Speed: 2150MB/s
- Write Speed: 1200MB/s
- IOPS: 140k/80k
- Warranty: 2yr
Was [£149.99] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Samsung SM951 512GB M.2 PCI-e Gen3 8Gbps x 4 AHCI Solid State Drive (MZHPV512HDGL-00000) @ £229.99 inc VAT
Specification:
- MLC NAND
- Write Speed: 1500MB/s
- IOPS: 140k/85k
- Warranty: 2yr
Was [£299.99] Inc. VAT
Only £229.99 inc VAT.
ORDER NOW
Samsung SM951 128GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive (MZVPV128HDGM-00000) @ £85.99 inc VAT
The new, best thing in storage technology, NVMe, which has been hot property in the server market due to it's extreme transfer speeds, has now reached the desktop market. The Samsung SM951 M.2 PCIe NVMe SSD is the new performance leader in M.2 form factor SSD's. Providing up to 2000MB/s read and 650MB/s write sequential data transfer rates, along with astounding random I/O ratings of 300k reads and 83k writes.
The Samsung SM951 (NVMe) is compatible as a boot device in a wide variety of systems with a free PCIe 2.0/3.0 M.2 socket. This includes Z170/Z97/X99 based motherboards, modern notebooks, and tiny form factor PC's like the Intel NUC. It can also act as additional super high speed storage in almost any desktop with a spare PCIe slot when combined with a PCIe adapter.
Key Features:
- Extreme performance - up to 2000/650 sequential read/write data transfer rates and 300k/83k read/write random IOPS
- Bootable in Windows 7/8, Mac OSX (2006-2010 Mac Pro only) and Linux
- PCIe 3.0 device, backwards compatible with PCIe 2.0
- Small M.2 form factor plugs straight into your PCIe-based M.2 socket with no additional cables required
NOTE: Some M.2 motherboards only support SATA 6Gbps speeds or PCI-e x 2 lanes. You need to make sure your board supports NVMe and PCI-E x4 Lanes to get the full speed from this SSD.
Specification:
- M.2 PCI-E 3.0 (x4) interface on an NVMe Compatible Motherboard
- MLC NAND
- Write Speed: 650MB/s
- IOPS: 300k/83k
- Warranty: 2yr
Was [£89.99] Inc. VAT
Only £85.99 inc VAT - Arriving Tomorrow!
ORDER NOW
Samsung SM951 256GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive (MZVPV256HDGL-00000) @ £155.99 inc VAT
Specification:
- MLC NAND
- Write Speed: 1260MB/s
- IOPS: 300k/100k
- Warranty: 2yr
Was [£179.99] Inc. VAT
Only £155.99 inc VAT - Arriving Tomorrow!!
ORDER NOW
Samsung SM951 512GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive (MZVPV512HDGL-00000) @ £289.99 inc VAT
Specification:
- MLC NAND
- Write Speed: 1550MB/s
- IOPS: 300k/100k
- Warranty: 2yr
Was [£329.99] Inc. VAT
Only £289.99 inc VAT - Arriving next Monday!!
ORDER NOW
Intel 750 Series 400GB PCIe 3.0 X4 HHHL Adaptor NVMe Solid State Drive (SSDPEDMW400G4X1) @ £299.99 inc VAT
The Intel SSD 750 Series is Intel's first PCIe* Gen3 x4 SSD developed for the client enthusiast and workstation markets. The Intel SSD 750 Series is architectured with the new high performance controller interface - Non-Volatile Memory Express* (NVMe') - delivering outstanding performance, low latency and Quality of Service. NVMe is a standardized interface that enables higher performance and lower latency than previous generations. The Intel SSD 750 Series offers capacities of 400GB and 1.2TB in Add-ln card and 2.5-inch (SFF-8639 connector) form factors.
The Intel SSD 750 Series is Intel's highest performing client drive specifically designed for the PC enthusiast and Workstation systems with demanding storage workstation requirements. Wth PCIe Gen3 x4 support and NVMe queuing interface, the Intel SSD 750 Series delivers excellent sequential read performance of up to 2.4 GB/s and sequential write speeds of up to 1.2 GB/s. The Intel SSD 750 Series delivers random read IOPS of up to 440K and random write IOPS of up to 290K for 4KB operations. Also, by taking advantage of the direct path from the storage to the CPU by means of NVMe, the Intel SSD 750 Series exhibits low latency of less than 20 ps for sequential access to the SSD.
Features:
- PCIe Gen3 x4 with NVMe interface
- Half Height Half Length (HHHL) Add-in-Card
- Consistently Higher IOPS and throughput
- Sustained low latency
- Enhanced power-loss data protection
- Temperature Monitoring and Logging
- End-to-End Data Protection
Specification:
- Capacity: 400GB
- Form Factor: HHHL Half Height PCI-E
- Interface: PCI-E 3.0 (x4)
- Host Controller: NVMe
- Flash Type: Intel 20nm MLC NAND
- Max Read: 2200MB/s
- Max Write: 900MB/s
- Max IOPS (Random Read 4k): 430,000
- Max IOPS (Random Write 4k): 230,000
- Warranty: 5yr
Was [£319.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Intel 750 Series 800GB PCIe 3.0 X4 HHHL Adaptor NVMe Solid State Drive (SSDPE2MW800G4X1) @ £549.95 inc VAT
Features:
Specification:
- Capacity: 1.2TB
- Max Read: 2100MB/s
- Max Write: 800MB/s
- Max IOPS (Random Read 4k): 420,000
- Max IOPS (Random Write 4k): 210,000
- Warranty: 5yr
Was [£599.99] Inc. VAT
Only £549.95 inc VAT.
ORDER NOW
Intel 750 Series 1.2TB PCIe 3.0 X4 HHHL Adaptor NVMe Solid State Drive (SSDPEDMW012T4X1) @ £799.99 inc VAT
Features:
Specification:
- Capacity: 1.2TB
- Max Read: 2400MB/s
- Max Write: 1200MB/s
- Max IOPS (Random Read 4k): 440,000
- Max IOPS (Random Write 4k): 290,000
- Warranty: 5yr
Was [£829.99] Inc. VAT
Only £799.99 inc VAT.
ORDER NOW
Elite Tier SSD's for those who want the best in SSD technology, insanely fast, definitely Elite Tier hardware !!!!
View Our Full SSD Range - Click Here!
You have the capacity wrong in the description of the Intel 800GB :p
Going to be picking up a Samsung soon enough, don't know whether to get the AHCI or NVMe version - Is there a vast difference (£50 worth) between them?
Thanks buddy!
I'd always buy the fastest personally and the NVMe ones are much faster on operations so I can only assume if its an OS drive it would be even quicker, whether or not you will notice though I am unsure.
I would always buy the fastest. :D
Does NVMe mean x4 dedicated PCIe lanes or is there more to it? I know Z97 has only x2 lanes to the CPU. I'm not even sure all X99 have x4 lanes, does Z170 have x4 lanes as standard?
Just checking, these can go in any PCI-E slot?
If so I'm guessing my Motherboard is fine?
The PCIe card ones should go in a x4 PCIe slot. The M2 ones can go in a PCIe slot with an adapter card.
You may find that with the x4 PCIe slot that your graphics card is reduced to x8 instead of 16x.
The Intel one would fit in a PCI-E slot just as a graphics card would - It would run at its maximum speed if you popped it in a PCI-e 3.0 x4 slot, it'd be operational but slower if you popped it in anything else.
The Samsung M.2 drives fit in a special M.2 slot which some Z97 motherboards have, and almost all X99/Z170 boards have - Unfortunately your board doesn't have one. You can pick up an M.2 to PCI-e adapter if you were to buy the Samsung.
Z170 has 16 lanes from the CPU, and 20 lanes from the Z170 chipset. - X99 has 28 lanes with a 5820k CPU, which are all CPU lanes, and 40 lanes with the 5930k and 5960x, which are also all CPU lanes.
Any of the SSDs listed above would use 4 of the lanes available, if they're available. All X99 boards, minus Gigabyte ones, have a PCI-e 3.0 x4 M.2 slot natively. The Gigabyte ones only run at PCI-e 2.0 x4 which means half the speed available from the M.2 SSD.
You can get an adapter, and as long as you're not running dual graphics cards it should work fine :)
We looked at the Lycom DT-120 which seemed a great solution but the factory inform us it is not bootable with Samsung SM951 series, so we cancelled our order.
Do you know of a tried and tested bootable PCI-E card for the M.2 PCI-E SSD's such as SM951?
Obviously the one which Plextor use works but they do not sell it separately.
Just had a look, to see how they work. Very simple! Fine with my SSD now but always good to consider for the future. Will definitely get a larger drive next time though.
Oh wow - I did not know this. Is it not bootable even with the BIOS updates and using the NVMe versions? I know earlier AHCI models had trouble booting in a lot of motherboards, but since then the situation has improved a lot with BIOS updates and the like.
I emailed the factory again this morning for another update, but I suspect the answer will be the same as they probably do not test.
Lycom DT-120 works, but only as a storage drive, so far factory says SM951 does not support boot function.
Be interested to know if anyone have an SM951 in a PCI-E card which is bootable.
Otherwise only solution is to essentially do a full upgrade to Z170 or X99. :)
Don't Asus sell their Hyper adapter separately? I'd imagine that's bootable, but I have no evidence to suggest so.
