Just asked for a refund from CD Keys as they haven't send the code yet and instead I've bought via the US Xbox store and it was so much easier than I thought.
I changed my region on Xbox.com, then I added a $60 gift card that I bought from Amazon.com (by adding a US address to my address book), and then just bought FIFA 16 via Xbox.com using the gift card. Cheaper, and it means I should be able to play tomorrow
Are you on Xbox or PS4?
Pretty sure FIFA 14 removed the L2 requirement, wasn't aware it was still needed for particular tricks though? Ahh juggling and the fakes
ps3ud0![]()
Amazon order still not dispatched![]()
Could some please check to see if the game has coop 2v2 season online (play with a friend locally).
Going out to buy a physical copy this afternoonno doubt will be roped into buying some Fifa points, then a late night building up some wins to get some money in the bank!!
Can't wait!
Mine hasn't despatched either but something else I ordered the same day has been. I'm not sure that's a good sign.
Amazon normally dispatch my pre-orders two days before the required date, then it normally turns up a day before.
Doesn't look like that is happening this time![]()
I know it's obvious but remember to use your coin boosts that you can buy in-game , it really helps at the start !
No, thanks for reminding me! That like where you get $1000coin bonus per win etc?
That reminds me, is it better to set it to easy to play a few AI games to start and absolutely tank them to get more of a bonus?
Want to build up a bit of bank before building a cheapish UT team and taking it online.
