I bought some tyre shine, because you can never have enough tyre shine.
Bizarre thing is it also came with a sachet of moisturising balm, I guess it's for those who appreciate soft hands after a vigorous rubbing session.
Also use them in shower to dry it down after use.
- from Vivobarefoot. Its ridiculously comfy.
You do what? You dry your shower after you use it? Why?
- also it is less hassle to clean it on the weekly bathroom clean up.
After every shower - I hate water marked and dirty showers -- also it is less hassle to clean it on the weekly bathroom clean up.
I must also say it is quite easy now I have those shower panels instead of tiles and new shower screen is frame less so no nooks and crannies.![]()
Good on you. I bet you iron your underwear too!![]()
More travelling purchases arrived.
Wanted a travel tripod, couldn't decide between the Velbon UT43D II and the Cullmann Magic CompactPod. So I ordered both to decide. Both are good, but the Velbon wins.![]()
