Can someone correct me if am wrong:
1)I need TTKing to level past 34
2)I need TTKing to get third subclass and Artifact and New version of Ghost
3)I need TTKing to play Saturn planet
the only expansion i got install is Destiny Expansion Pass one and two which i brought three month back.
The thing is my character is now level 40
got the third subclass titan sunbreaker and artifact and year two weapons, Got ghost and done three stages on planet Saturn which is Enemy of my enemy, The Dreadnaught and Regicide.
SO the question is have i got the full version of TTKing install?
They really need to make it so the cryptarch just auto checks your highest gear for your top light level. I'm getting bored of having to equip all the top gear each time I visit the cryptarch and then checking if each engram is better than the equipped one before doing the next.
Seems so.
It does get tedious, also and maybe I'm going to get shouted down on this but they need to allow the sending of stuff to the vault while on mission/patrol, you can easily do it via the app so why not in game?
Postmaster? Anything you don't/can't pickup automatically goes to the tower.
If that's the one with the room at the end with poison in the floor and fire on the ceiling then I solo'd that earlier and it was tough.
I ended up standing between a set of stairs and some horizontal cylinders and using and auto rifle and sword to clear the adds and blights before damaging the echo. Then I sniped him down in one go after the second add spawn but I could only do it because I got the black spindle yesterday and it auto reloads after 3 critical hits.
The strategy of clear adds/blights, damage echo, repeat should work though but did I mention that it is tough?
Good luck.
