- 29 Dec 2009
Took a break from buying car parts and treated myself to this... for the car
You'll look the biz on all those school trips![]()
Bit of a bargainThis will do for a rucksack for when I have days out
Padded space for laptop and a tablet and still plenty of room for camera etc
4 Silver is a strange choice for car use as the 3+ Black is better and cheaper, just lacking the screen.
The battery life is particularly poor on the 4 series![]()
The screen is the seling point of the silver though. I have the 4 black, battery lasts about an hour and half. I got a 2 pack of compatibles (Smatree) from Amazon (or ebay - i forgot), they work fine, you also get a charger that holds 3 batteries too which is handy. Think i paid about £12 for it all.
Anything more than 1080p will fill your 64gb!Yep that's why I got the 4 Silver too, you can see what you're filming, Also have the Smatree batteries and 3 port charger, works well and not had a problem with battery life really, got 4 so that will not even fill a 64gb card on 1080p![]()
You don't need the retina MacBook and iPad, my bet is you won't use the iPad
i got a couple of 64's for mine but i'll only be filming in 1080p for my holidays, as much as i'd like to film 4k, it'll fill my 64gb in an hour.
Two pairs of 511 slims.
